I have A Whirlpool Cabrio Washer and whenever it goes in to the spin cycle , it starts banging and I get an error code UL not sure which parts i need to fix it .
Under the top of the machine is a tech sheet which will tell you how to run some tests.
UL is an unbalanced load indicator, which in this model may indicate a whole lot of things that may or may not be related to an unbalanced load.
Try to use the diagnostics in in the tech sheet to narrow things down.
I'm having the same problem as stankiewicz93. If I move the clothes around after I get the uL error code it sometimes solves the problem. Sometimes I have to rebalance the load several times before the machine will complete its cycle. Even if I only put a few pieces of clothing in the machine it will still do this. I ran the built in diagnostics and the F32 and F51 codes were stored in memory. It seems that there is something mechanical (spring or mount) that allows the tank to move around too much. How can an electronic problem like F51 allow the tank to move around too much?
NEWJ :confused:
