| » kenmore he2 plus washer not aggitating. |
Quote:
Could you please supply us with the model number of your washer. So we can verify your code and be more effective for you. It sounds like you have a motor control problem. but that would not be an F01 Code on that style unit. I doubt you need the water level switch since your machine fills and drains properly. Thanks,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Thanks,
The model number was helpful. Based on the information available, this unit should not have an F01 fail code. Could the code display be F07 or F11 ? I would expect these two codes, not an F01, for your particular description. You may want to re-run the diagnostics test and and the diagnostic fail code list. I'm still stuck at MCU or communication error.
__________________
The code comes up F01. I'm thinking maybe the ccu board. I'm going to do some voltage checks when I get home tonight. Every once in a while the drum will try to turn. It is a quick little jerk that if your not looking for it you would never notice it. I think that the fact that it does that the mcu board is probably functioning. Maybe the motor is also faulty.
Quote:
Great idea, the voltage checks and all. It keeps sounding more and more like an MCU board problem, you'll know for sure when the test is done.
__________________
| Display Modes | |
| washer stopped aggitating | stealhead | Washer Repair | 1 | 07-28-2011 06:34 PM |
| Clothes Washer fills, but won't start aggitating cycle | JeffandSara | Washer Repair | 3 | 05-02-2011 06:20 AM |
| GE washer not aggitating or spinning 2 years ol | chandajean | Washer Repair | 1 | 12-12-2009 06:33 PM |
| washer stopped aggitating and won't drain | djbrandy | Washer Repair | 4 | 01-06-2009 07:57 AM |
| washer not aggitating or spinning | ravensy2k | Washer Repair | 3 | 03-15-2008 09:10 PM |
