Discuss
Washer Repair
 in
Washer Repair
I have a problem with water filling the tub to high. On a full load wash cycle the water fills
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer Repair
  #1 (permalink)
Old 08-02-2011, 02:49 PM
Junior Member
Richard Dulmes is on a distinguished road
Default Washer Repair
Model Number: WPRB922OCOWW   Brand: GE   Age: 5 - 10 years
I have a problem with water filling the tub to high. On a full load wash cycle the water fills to high and runs out of the over flow tube and eventually on the floor. I was told that the plastic box on the side of the tub governs the height of the water.Does it need to be cleaned if so how does it come off ?
Related Models
General Electric WPRB9250C0CC Washer
General Electric WPRB9250C0WW Washer
General Electric WPRB9250D0CC Washer
General Electric WPRB9250D0WW Washer
General Electric WPRB9250D1CC Washer
General Electric WPRB9250D1WW Washer
General Electric WPRE5240D1WW Washer
General Electric WPRE6100G0WT Washer
General Electric WPRE6100G1WT WASHER
General Electric WPRE6100G2WT WASHER
General Electric WPRE6100G3WT WASHER
General Electric WPRE6150H0WT WASHER
General Electric WPRE6150H1WT WASHER
General Electric WPRE6150H2WT WASHER
General Electric WPRE6150K0WT WASHER
General Electric WPRE6150K1WT WASHER
General Electric WPRE6150K2WT WASHER
General Electric WPRE6150K3WT WASHER
General Electric WPRE6280D1WW Washer
General Electric WPRE6280DCWW Washer
General Electric WPRE8100G0WT Washer
General Electric WPRE8100G1WT WASHER
General Electric WPRE8150H0WT WASHER
General Electric WPRE8150H1WT WASHER
General Electric WPRE8150H2WT WASHER
General Electric WPRE8150K0WT WASHER
General Electric WPRE8150K1WT WASHER
General Electric WPRE8150K2WT WASHER
General Electric WPRE8150K3WT WASHER
General Electric WPRE8320H2WT WASHER
General Electric WPRE8320H3WT WASHER
General Electric WPRE8350H0WT WASHER
General Electric WPRE8350H1WT WASHER
General Electric WPRE8350H2WT WASHER
General Electric WPSB8060B0CC Washer
General Electric WPSB8060B0WW Washer
General Electric WPSB8060B1CC Washer
General Electric WPSB8060B1WW Washer
General Electric WPSB8060B9CC Washer
General Electric WPSB8060B9WW Washer
General Electric WPSB9080B0CC Washer
General Electric WPSB9080B0WW Washer
General Electric WPSB9120B0CC Washer
General Electric WPSB9120B0WW Washer
General Electric WPSE3120Y1WW Washer
General Electric WPSE4200A0AA Washer
General Electric WPSE4200A0WW Washer
General Electric WPSE4270A0AA Washer
General Electric WPSE4270A0WW Washer
General Electric WPSE5290A0AA Washer
General Electric WPSE5290A0WW Washer
General Electric WPSE7001A0AA Washer
General Electric WPSE7001A0WW Washer
General Electric WPSE7002A0AA Washer
General Electric WPSE7002A0WW Washer
General Electric WPSE7003A0AA Washer
General Electric WPSE7003A0WW Washer
General Electric WPSE7003A1WW Washer
General Electric WPSE7003A9WW Washer
General Electric WPSE7003B9WW Washer
General Electric WPSF4170V0AA Washer
General Electric WPSF4170V0WW Washer
General Electric WPSF4170V1AA Washer
General Electric WPSF4170V1WW Washer
General Electric WPSF4170W0AA Washer
General Electric WPSF4170W0WW Washer
General Electric WPSF4170W1AA Washer
General Electric WPSF4170W1WW Washer
General Electric WPSF4170W2AA Washer
General Electric WPSF5170W0AA Washer
General Electric WPSF5170W0WW Washer
General Electric WPSF5170W1AA Washer
General Electric WPSF5170W1WW Washer
Whirlpool WPSHAW0 PURE DELIVERY WATER PUMP
General Electric WPSL3120W0WW Washer
General Electric WPSL3120W2WW Washer
General Electric WPSP4170W0WW Washer
General Electric WPSP4170W1WW Washer
General Electric WPSQ3120T2AA Washer
General Electric WPSQ3120T2WW Washer
General Electric WPSQ3120T5AA Washer
General Electric WPSQ3120T5WW Washer
General Electric WPSQ3120T6AA Washer
General Electric WPSQ3120T6WW Washer
General Electric WPSQ3120T8AA Washer
General Electric WPSQ3120T8WW Washer
General Electric WPSQ3120T9AA Washer
General Electric WPSQ3120T9WW Washer
General Electric WPSQ3120TAAA Washer
General Electric WPSQ3120TAWW Washer
General Electric WPSQ4160T2AA Washer
General Electric WPSQ4160T2WW Washer
General Electric WPSQ4160T5AA Washer
General Electric WPSQ4160T5WW Washer
General Electric WPSQ4160T6AA Washer
General Electric WPSQ4160T6WW Washer
General Electric WPSQ4160T7AA Washer
General Electric WPSQ4160T7WW Washer
General Electric WPSQ4160T8AA Washer
General Electric WPSQ4160T8WW Washer
General Electric WPSQ4160T9AA Washer
General Electric WPSQ4160T9WW Washer
General Electric WPSQ4160TAAA Washer
General Electric WPSQ4160TAWW Washer
General Electric WPSR3090V0AA Washer
General Electric WPSR3090V0WW Washer
General Electric WPSR3090V1AA Washer
General Electric WPSR3090V1WW Washer
General Electric WPSR3100W0AA Washer
General Electric WPSR3100W0WW Washer
General Electric WPSR3100W1AA Washer
General Electric WPSR3100W1WW Washer
General Electric WPSR3100W2AA Washer
General Electric WPSR3100W2WW Washer
General Electric WPSR3120W0AA Washer
General Electric WPSR3120W0WW Washer
General Electric WPSR3120W1AA Washer
General Electric WPSR3120W1WW Washer
General Electric WPSR3120W2AA Washer
General Electric WPSR3120W2WW Washer
  #2 (permalink)
Old 08-03-2011, 04:44 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for General Electric WPRB9220C0WW Washer | AppliancePartsPros.com
It does not control the water fill height.
As far as I know it does not come off.
Sounds like a fill assembly (switch pressure Item 10 in Section 1) problem.
This switch is actually a pressure switch. It has a tube that runs down to the bottom of the tub, as water fills the tub, air is trapped in the tube. As the water rises, the air pressure in the tube increases until it reaches the switch's set point then the switch activates turning off the water and starting the agitate.
Possible problems.
1. Gunk blocking water from entering the tube. Remove the tube at the switch and blow into it to clear the plug.
2. Cracks or holes in the tube allowing the air to escape. Inspect the tube. Also check that it is tight on the switch, if not, cut off half an inch and re-seat it.
3. The switch is toast. Get a piece of tubing with the same internal diameter and attach this to the switch. Start a fill, then blow into the tube. You should be able to stop the water flow without blowing very hard.
If you cannot stop it the switch is toast.
It sounds like it does not overfill at lower water level settings so I doubt the above test will tell you anything.
But if the water does not shut off as soon as the switch activates then the water valve may not be closing fast enough. This would be a long shot.
Spo if the tubing is good then I would replace the switch.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer repair mjwhiting Washer Repair 1 04-07-2010 09:52 AM
Washer repair elw327 Washer Repair 0 03-24-2010 10:42 AM
washer repair ekoechle@frontiernet.net Washer Repair 1 02-17-2010 04:39 AM
Need help with washer repair fa9999 Washer Repair 3 05-31-2008 12:18 PM
washer repair godfreywfree Washer Repair 1 08-29-2007 09:19 PM
