fordsawyer
#1 Posted : Monday, August 1, 2011 8:48:21 PM(UTC)
fordsawyer
We've got an older GE top loading washing machine it suddenly quit going through the cycles. I can move the dial manually and the cycles work fine but the timer that moves the machine automatically through them isn't working. I've been timing each cycle myself and manaully advancing the dial when it's time for the next. Is there any way you diagnose from this much information which component has failed? Is it actually the timer motor or another component that directs the timer? Is there anything I can do to diagnose the problem to find out what I actually need? I've got the front panel off but I haven't begun to remove any parts. It looks very complex with a twisted maze of wires running in all directions. Do you think I would be able to find some kind of timer motor that would be compatible with an older machine like this? I don't even know how old it actually is but I haven't found any reference for this model anywhere. It's been a very very good washer though and I would like to repair it if it is still worth doing.
sidfink43
#2 Posted : Wednesday, August 3, 2011 5:38:17 PM(UTC)
sidfink43
I cannot get your model number to come up, but in general timers are not repairable items. If you like the machine go ahead and change out the timer and see if that fixes things. It should.
fordsawyer
#3 Posted : Friday, August 5, 2011 3:16:46 PM(UTC)
fordsawyer
I can't find any reference to the model I have either. I was wondering how can I tell if another timer for a different model could be substituted in replacement of the one I have?
sidfink43
#4 Posted : Friday, August 5, 2011 5:12:43 PM(UTC)
sidfink43
A lot of times timers are interechangeable with different models. Take a picture of your console and then take your timer into an appliance parts store and see what they can do. Also check with a local repair shop, they may be able to help you out.
