Lewis Scott
#1 Posted : Monday, August 1, 2011 8:50:15 AM(UTC)
Lewis Scott
My washer in the middle of a cycle just turns off and keeps door locked. Not sure what to look for. Please help
sidfink43
#2 Posted : Wednesday, August 3, 2011 5:26:26 PM(UTC)
sidfink43
Inside the lower service panel or under the top should be tech notes that will tell you how to put it into a diagnostic mode. Also, you should be able to reach in from the lower part of the machine after the lower service panel is off to get to a tab which you can pull to manually unlock the door if you need to.
