Discuss
Water doesn't stop in rinse mode
 in
Washer Repair
Hello, I had a problem with my washer where the water wasn't stopping to fill during the initial cycle (wash),
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Water doesn't stop in rinse mode
  #1 (permalink)
Old 03-24-2009, 10:22 PM
Junior Member
whirlpool_nyc is on a distinguished road
Default Water doesn't stop in rinse mode
Model Number: LCR7244DQ3   Brand: Whirlpool   Age: 1 - 5 years
Hello,
I had a problem with my washer where the water wasn't stopping to fill during the initial cycle (wash), so after doing some research, I was able to identify the problem to be the water level switch. I ordered this part (AP2915842, Part# 3966789) and the problem has now gone away. Strangely enough the water does stop filling correctly at the wash cycle, but now won't stop filling during the rinse cycle. Any ideas why this might be?
Related Models
Whirlpool LCR7244DQ3 COMPACT AUTOMATIC WASHER
Whirlpool LCR7244DQ4 COMPACT AUTOMATIC WASHER
Whirlpool LCR7244DQ5 AUTOMATIC WASHER
Whirlpool LCR7244DZ0 DIRECT-DRIVE WASHER
Whirlpool LCR7244DZ1 AUTOMATIC WASHER
Whirlpool LCR7244DZ2 COMPACT AUTOMATIC WASHER
Whirlpool LCR7244DZ3 COMPACT AUTOMATIC WASHER
Whirlpool LCR7244DZ4 COMPACT AUTOMATIC WASHER
Whirlpool LCR7244DZ5 AUTOMATIC WASHER
Whirlpool LCR7244HQ0 COMPACT AUTOMATIC WASHER
Whirlpool LCR7244HQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LCR7244HQ2 COMPACT AUTOMATIC WASHER
Maytag LCRE200 RANGE- F/S STD ELE
Maytag LCRE300 RANGE- F/S STD ELE
Maytag LCRE350 RANGE- F/S STD ELE
Maytag LCRE400 RANGE- F/S STD ELE
Maytag LCRE600 RANGE- F/S STD ELE
Maytag LCRE650 RANGE- F/S STD ELE
Maytag LCRE655 RANGE- S/C F/S ELE
Maytag LCRE682 RANGE- S/C F/S ELE
Maytag LCRE683 RANGE- S/C F/S ELE
Maytag LCRE700 RANGE- S/C F/S ELE
Maytag LCRE750 RANGE- S/C F/S ELE
Maytag LCRE800 RANGE- S/C F/S ELE
Maytag LCRE805 RANGE- S/C F/S ELE
Maytag LCRE883 RANGE- S/C F/S ELE
Maytag LCRG200 RANGE- F/S STD GAS
Maytag LCRG300 RANGE- F/S STD GAS
Maytag LCRG305 RANGE- F/S STD GAS
Maytag LCRG350 RANGE- F/S STD GAS
Maytag LCRG355 RANGE- F/S STD GAS
Maytag LCRG382 RANGE- F/S STD GAS
Maytag LCRG383 RANGE- F/S STD GAS
Maytag LCRG400 RANGE- F/S STD GAS
Maytag LCRG405 RANGE-F/S CONT CLEAN GAS
Maytag LCRG500 RANGE- F/S STD GAS
Maytag LCRG501 RANGE- F/S STD GAS
Maytag LCRG502 RANGE- F/S STD GAS
Maytag LCRG505 RANGE- F/S STD GAS
Maytag LCRG560 RANGE- F/S STD GAS
Maytag LCRG583 RANGE-F/S CONT CLEAN GAS
Maytag LCRG600 RANGE- F/S STD GAS
Maytag LCRG601 RANGE- F/S STD GAS
Maytag LCRG602 RANGE-F/S CONT CLEAN GAS
Maytag LCRG700 RANGE- S/C F/S GAS
Maytag LCRG705 RANGE- S/C F/S GAS
Maytag LCRG750 RANGE- S/C F/S GAS
Maytag LCRG755 RANGE- S/C F/S GAS
Maytag LCRG760 RANGE- S/C F/S GAS
Maytag LCRG760A RANGE- S/C F/S GAS
Maytag LCRG783 RANGE- S/C F/S GAS
Maytag LCRG800 RANGE- S/C F/S GAS
Maytag LCRG805 RANGE- S/C F/S GAS
Maytag LCRG860 RANGE- S/C F/S GAS
Maytag LCRG860A RANGE- S/C F/S GAS
Maytag LCRP200 RANGE- F/S STD GAS
Maytag LCRP205 RANGE- F/S STD GAS
Maytag LCRP300 RANGE- F/S STD GAS
Maytag LCRP382 RANGE- F/S STD GAS
Maytag LCSE600 SURFACE UNIT- ELE
Maytag LCSE601 SURFACE UNIT- ELE
Maytag LCSG500 SURFACE UNIT- GAS
Maytag LCSG501 SURFACE UNIT- GAS
Maytag LCSG560 SURFACE UNIT- GAS
Maytag LCSG600 SURFACE UNIT- GAS
 LCU240CP Air Conditioner
 LCU340CP Air Conditioner
Amana LD10 COMMERCIAL MICROWAVES
Amana LD10D COMMERCIAL MICROWAVES
Amana LD10D2 COMMERCIAL MICROWAVES
Amana LD10MP COMMERCIAL MICROWAVES
Amana LD10MPS COMMERCIAL MICROWAVES
 LD25EL Dehumidifier
 LD40 Dehumidifier
 LD40E Dehumidifier
 LD50EBL Dehumidifier
 LD50EL Dehumidifier
 LD50ELY5 Dehumidifier
Amana LD510 COMMERCIAL MICROWAVES
Amana LD510D COMMERCIAL MICROWAVES
Amana LD510M COMMERCIAL MICROWAVES
Amana LD510P COMMERCIAL MICROWAVES
Amana LD510S COMMERCIAL MICROWAVES
 LD65EL Dehumidifier
 LD65ELY5 Dehumidifier
Gaggenau LD816-610
Gaggenau LD816-620
 LDC22720ST Refrigerator
 LDC22720SW Refrigerator
 LDC22720TT Refrigerator
Admiral LDE1000ACE DRYER- ELE
Admiral LDE1000AKE DRYER- ELE
Admiral LDE1000GGE DRYER- ELE
Maytag LDE110 DRYER- ELE
Maytag LDE18CA MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE18CM MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE18CS MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE18CT MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE19CA MANUAL, PARTS (DRYER ELE)
Maytag LDE19CD MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE19CS MANUAL, PARTS (DRYER ELE)
Maytag LDE19CT MANUAL, PARTS (DRYER ELE)
Maytag LDE210 DRYER- ELE
Maytag LDE212 DRYER- ELE
Maytag LDE21CS MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE22CS MANUAL, PARTS (DRYER ELE)
Maytag LDE22CT MANUAL, PARTS (DRYER ELE)
Maytag LDE23CD MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE24CA MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE24CM MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE24CS MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE24CT MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE25CS MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE26CA MAYTAG COMMERCIAL LAUNDRY (DRYER ELE)
Maytag LDE26CD MAYTAG COMMERCIAL LAUNDRY (DRYER ELE)
Maytag LDE26CS MANUAL, PARTS (DRYER ELE)
Maytag LDE26CT MAYTAG COMMERCIAL LAUNDRY (DRYER ELE)
Maytag LDE27CA MANUAL, PARTS (DRYER ELE)
Maytag LDE27CD MAYTAG COMMERCIAL LAUNDRY (DRYER ELE)
  #2 (permalink)
Old 03-25-2009, 06:00 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for WHIRLPOOL LCR7244DQ3 | AppliancePartsPros.com
Here is service tech sheets
https://www.servicematters.com/docs/...%203967457.pdf
https://www.servicematters.com/docs/...%203966815.pdf
Hopefully the above will help.
I would try different cycles and water temperatures, perhaps the unit does something strange if only filling with cold during rinse.
I would do as much testing as possible using the tech sheets.
If it ends up by the process of elimination that the control board is a likely culprit, it may not be worth fixing.
Hopefully someone with experience on this unit will jump in and supply a easy solution.
__________________
  #3 (permalink)
Old 03-25-2009, 07:27 AM
Junior Member
Default
Hello,
Actually, now the water doesn't stop filling wash mode also. It worked the first time. Do you think something in the washer is damaging the water level switch?
  #4 (permalink)
Old 03-25-2009, 08:49 AM
Senior Expert
APP Volunteer
Default
I am assuming that you can stop the filling by turning the dial to off or unplugging the unit.
Washer should not be able to mess up the level switch unless it is somehow getting water up the tube into the switch's bellows.
I would get a piece of tubing with the same internal diameter as the pressure tube. Attach this to the level switch, start a fill then blow into this tube. You should be able to stop the fill without having to blow very hard.
If you cannot stop it, the switch is toast.
If the above is OK. Then put your finger over the machines fill tube and start a fill, you should be able to feel the pressure in the tube build up. Another way would be to put the end of the tube into a glass of water as it fills there should be bubbles forced out of the tube.
I cannot see how the tube attaches to the tub, some simply run down inside, others are attached to a fitting on the outside tub. Sometimes a piece of crud can get into the tube and stop the water from entering.
The above will confirm this or that you have a hole/crack in the tubing.
Sometimes just blowing into the tube will clear it but since you had the problem and then it worked once it is probably best to confirm this. You may have cleared it the first time but it is floating around and will just re-clog it again. You may have to take the unit apart to clear it.
__________________
  #5 (permalink)
Old 03-25-2009, 07:32 PM
Junior Member
Default
Thank you for the helpful suggestions.
I am not sure if the original water level switch was bad, but now that it's fixed, I'm not taking chances. I went to the hardware store to purchase a new tube to run it from the tank directly to the switch. I suspect that there was a slow leak in the connection between the water level switch and the plastic cover.
Again, thanks so much. I think appliancepartspro has a great product and support system. I would buy again from this site just because you guys are providing such a valuable service.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper Washer Will Not Fill At Rinse Mode BrownOctober Washer Repair 5 04-13-2013 11:16 AM
Washing machine does not SPIN during RINSE mode. Fastmhz Washer Repair 5 02-20-2013 09:20 AM
only rinse mode works randomjoe1 Dishwasher Repair 1 05-28-2009 06:22 PM
GE TRITON III won't stop rinse cycle HELP! patpeery@aol.com Dishwasher Repair 9 11-17-2008 12:25 PM
Dryer won't stop running in automatic mode jgk Dryer Repair 5 11-03-2008 02:51 AM
