| » Error code F11 |
Model Number: Duet HT GHW9400PW Brand: Whirlpool Age: 5 - 10 years
Error code F11; Even after resetting it keeps happening; Is there a common fix?
Hello pgeden. The F11 code if for a faulty motor controller unit.
Possible Causes/Procedure - Verify the shipping system including shipping bolts and spacers are removed, and power cord out of the unit. - Check if washer is on a dedicated circuit. Other devices on same circuit can create line noise and cause this issue. - Unplug washer or disconnect power - Check the neutral feed to the MCU and CCU from the AC line filter. - Check all wire harness connections between the Motor & MCU, and MCU to CCU, are not broken or wires detached and connector internal pins are visible. - Make sure that all the connectors are fully seated. - Plug in washer or reconnect power cord. If all of this is good, you will need to replace the motor controller. Hope this helps. Part number: AP3861856 Pump and motor parts, optional parts (not included) replacement parts for WHIRLPOOL GHW9400PW0 AUTOMATIC WASHER | AppliancePartsPros.com
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Jeff K. / APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| LG error code OE - drain error | JPotter | Washer Repair | 0 | 04-01-2011 07:20 AM |
| F1 error code | D Eddy | Oven Repair (including Ranges and Cooktops) | 0 | 07-14-2010 12:14 AM |
| Error Code F2 | Stan123 | Oven Repair (including Ranges and Cooktops) | 1 | 05-12-2010 02:53 PM |
| frigidaire error code F10 - not listed in your error codes | Skully26 | Oven Repair (including Ranges and Cooktops) | 2 | 02-16-2010 04:29 AM |
| error code | Shirl90 | Oven Repair (including Ranges and Cooktops) | 0 | 10-12-2009 05:25 PM |
