I have aFrigidaire front loading washer that will not go through the spin cycle. EVrything else works fine. I have read that perhaps it is the door lock assembly. Any thoughts?
Inside the lower service panel are some tech notes that will tell you how to test things.
Focus on the speed/motor contorl unit and the door lock assembly. That is where these units usually fail.
Originally Posted by: sidfink43 Inside the lower service panel are some tech notes that will tell you how to test things.
Focus on the speed/motor contorl unit and the door lock assembly. That is where these units usually fail. Thank you!!
