My wash machine was in the middle of a load of clothes when the spin cycle started it made a loud grinding noise and will not spin, drain water, nothing. Any suggestions on what it might be?
Start by taking off the front cover and checking out the belt, motor and see if the transmission pulley turns freely. Also check the pump in case something drained into it and jammed it.
