| » Kenmore Elite Washer Leaking |
Model Number: 110-209502992 Brand: Kenmore Age: 1 - 5 years
I have a Kenmore Elite direct drive washer that is leaking prior to the agitation cycle.
I think that it is filling up too much because it overflows when it agitates. I have checked the fill valves to make sure that they are not sticking. My guess at this point is that it is pressure switch. Any thoughts or recommendations on replacement part numbers? Thanks, Rob Ads By Google Related Models |
Kayakcrzy and All,
Thanks for the input. I replaced the pressure switch and hose. I am still having the same problem. I went back and checked the hose and connections and they looked good. It has improved slightly but still overflows. To date I have checked the influent water valves and they shut off properly and checked the pump (no leaks). Does anybody have any other thoughts. Thanks, Rob |
Take the hose off the pressure switch, and blow through it. Also make sure there are no kinks in the pressure hose. Tom ********************************************
| Display Modes | |
| Kenmore Elite fridge - leaking from water filter housing | burgerman | Refrigerator & Freezer Repair | 24 | 07-31-2011 07:38 AM |
| help with kenmore elite oasis washer | tdavid64 | Washer Repair | 9 | 01-01-2010 03:05 PM |
| Kenmore Elite Washer Dead | Trebbor | Washer Repair | 3 | 10-02-2009 06:30 AM |
| Kenmore elite washer is leaking under washer | cbs | Washer Repair | 1 | 07-12-2009 06:27 PM |
| Kenmore Elite Washer | skifrk | Washer Repair | 1 | 03-22-2008 06:03 AM |
