| » Agitator "dogs" replacement |
Pull off top part of the agitator, where mama puts the fabric softener in, and then reach down, the center of the agitator, and pull off the cover that has a ridge going down the center. Once you remove that, you will see the screw, that you need to take out. Once you remove that, pull the agitator up and out. Now we need to seperate the top part of the agitator from the bottom section. So, put the agitator on the floor, and step on each side of the base of the agitator, and grab the auger part, and pull up hard and fast. Once you do that you will be able to get to the dogs from there. When you put it back together, line up the two nibbles on the base shaft to the two slits on the auger part, and set it on top of it, and get two screw drivers, and put them on each side, and press down hard at the same time, to set the auger. Good Luck. Tom ********************************************
| Display Modes | |
| Agitator "Ratchets"/moves in counterclokwise direction only | FCANST2 | Washer Repair | 10 | 09-26-2012 07:33 PM |
| Works on "rinse only" but stops on "wash". | Bill E | Dishwasher Repair | 5 | 05-27-2009 03:00 AM |
| Gallery Series ""Water Wont Go In"" | juancruz | Washer Repair | 1 | 04-28-2009 06:06 PM |
| Removal/replacement of "dogs" in agitator | PenceP | Washer Repair | 2 | 10-21-2008 09:11 AM |
| Agitator makes loud "smashing sound" during spin cycle | Spug | Washer Repair | 3 | 04-06-2008 05:43 PM |
