Washer will wash clothes but does not go into full spin at end of cycle resulting in really wet clothes. Please help family of 7.
Look for the tech sheets inside the control panel or behind the bottom access panel. Perform the troubleshooting as described in the tech sheets. Post the results.
Gene thanks for the info don't understand but appears to be working ok right know. If acts up I'll be back thank you for your response.
-- rgds greg
