SKIP22
#1 Posted : Friday, July 22, 2011 11:38:12 AM(UTC)
SKIP22
I have a problem while filling the washer, the water will not shut off and will overfill and force the door open. this will happen during the wash and/or rinse cycle.
sidfink43
#2 Posted : Sunday, July 24, 2011 5:33:02 PM(UTC)
sidfink43
Wow, that is not good, hope the flooding damage has not been bad.
Check the hose leading from the water level switch to the basket. If it is clogged it can cause your problem.
If after you clear it out you still have the problem, try changing out the water level switch, this part here.
Part number: AP4298882
Samsung Front Loading Washer - Noises Even When Manually Spun (Washer Repair)
by Guest 10/18/2023 3:20:35 PM(UTC)
Maytag Front Loading washer making noise (Washer Repair)
by joefigg1 5/22/2023 2:33:53 PM(UTC)
Maytag front loading washer (Washer Repair)
by Guest 4/23/2023 1:47:52 PM(UTC)
LG front loading washer powers up then turns off (Washer Repair)
by forrest318 10/15/2020 6:30:04 PM(UTC)
Samsung Front Loading Washer:Model# WF330ANB/XAA 01 (Washer Repair)
by vbetancur 1/16/2019 5:52:15 AM(UTC)
GE Front Loading Washer Door Lock and Leak (Washer Repair)
by 777Goody 1/28/2017 9:03:01 AM(UTC)
front loading washer door lock (Washer Repair)
by palmbound 4/15/2014 3:04:48 PM(UTC)
front loading washer drain pump motor (Washer Repair)
by kellyak 2/26/2014 2:42:08 PM(UTC)
Whirlpool Duet front loading washer (Washer Repair)
by Randy Berg 9/16/2013 3:04:45 PM(UTC)
My GE Front Loading Washer failed (Washer Repair)
by darekatra 7/31/2013 4:32:05 AM(UTC)
Maytag front loading washer randomly filling with water (Washer Repair)
by tcknw 7/22/2013 6:51:43 AM(UTC)
GE Front Loading Washer (Washer Repair)
by deb2ban 6/1/2013 3:04:01 PM(UTC)
Front Loading Washer will not run through a cycle (Washer Repair)
by mandm101301 5/27/2013 2:37:26 PM(UTC)
GE Front Loading Washer Won't Drain or Spin (Washer Repair)
by gblotter 2/8/2013 8:23:32 PM(UTC)
Ge Front loading washer (Washer Repair)
by JoeMaxim 1/7/2013 12:01:09 PM(UTC)
