szn9rg
#1 Posted : Thursday, July 21, 2011 9:46:37 AM(UTC)
szn9rg
I have a Maytag TL washer. Model MAV6000AWQ. The clothes are particallly wet when done. Watching machine cycle with a load, the spin would gradually spin to around 3/4 of normal speed. Part way through, it slows down considerablely and finishs the cycle that way. Both spin cycles in color and white with a load do this. Delicate cycle spins OK (with load) the entire cycle. Weird. All cycles spin fine empty. So far I've replaced belt, adjusted the thrust bearing , cleaned and lubed the motor pads, and verified brake disengages when spin counterclockwise and tube spins free (empty) -thrust alignment verification. I watched belts and didn't notice any slippage even when spin RPM was low. I verified pump worked. It drained tub in 1-2 minutes. Might be transmission but why does delicate cycle ( loaded) and empty tub in all 3 settings work yet color and white don't. No unusual noises but transmission housing is warm near bottom. Is that normal? Thanks in advance
sidfink43
#2 Posted : Saturday, July 23, 2011 5:55:11 PM(UTC)
sidfink43
I would check the pump and drain hoses for any obstruction, and replace th thrust bearing unless you are absolutely certain it is not the problem.
szn9rg
#3 Posted : Tuesday, July 26, 2011 6:27:50 PM(UTC)
szn9rg
The tub drains in about 60-70 seconds so I don't think the pump or drain hose would be the problem but I'll check There is no standing water in tub when spin cycle starts. The thrust bearings were replaces 1 1/2 years ago but I could put a new kit in and see what happens. Thanks
