karent
#1 Posted : Wednesday, July 20, 2011 1:31:18 PM(UTC)
karent
The ub will spin the agitator is moving and the hoses are clear. I replaced the pump. The water will drain into the pump but will not go through the hose to the sink. please help
#2 Posted : Wednesday, July 20, 2011 3:07:51 PM(UTC)
Remove the front panel and check the pump belt tension (instructions are attached). Make sure the belt is not worn out. If it is, replace both belts together.
- The belt kit Part number: AP4011179
Here are the breakdown diagrams and Replacement parts for MAYTAG A412 WASHER-TOP LOADING | AppliancePartsPros.com
P.S. Where exactly the drain hose goes?
File Attachment(s):
Pump belt adjustment.doc (51kb) downloaded 8 time(s).
Ge dishwasher will not drain (Dishwasher Repair)
by Handyman924 2/24/2017 8:05:27 PM(UTC)
maytag washer will not drain water (Washer Repair)
by mathy10544 12/13/2015 8:54:09 PM(UTC)
GE front load washer will not drain (Washer Repair)
by Sandmann01 6/22/2015 1:24:04 AM(UTC)
Washer will not drain (Washer Repair)
by Artnlp 5/3/2015 7:34:59 AM(UTC)
Washer will not drain in Normal cycle (Washer Repair)
by rober luck 4/20/2015 9:10:47 AM(UTC)
by charles140 10/10/2014 8:21:01 AM(UTC)
by hurler72 11/25/2013 10:59:35 AM(UTC)
topload washer will not drain or spin (Washer Repair)
by olac757@gmail.com 8/9/2013 9:08:21 PM(UTC)
Whirlpool dishwasher will not drain (Dishwasher Repair)
by PeterZ 8/6/2013 7:21:51 PM(UTC)
Washer will not drain or spin (Washer Repair)
by Fixit Dad 5/23/2013 4:26:49 PM(UTC)
by PepperVal 5/16/2013 8:36:29 AM(UTC)
Whirlpool Washer will not drain unless open and close lid (Washer Repair)
by twhistle 2/28/2013 8:16:58 AM(UTC)
Washer will not drain or spin, new pump and lid switch (Washer Repair)
by tangerine30680 1/26/2013 12:42:38 PM(UTC)
I replaced lid switch, still washer will not drain or spin (Washer Repair)
by dnschrstn 11/12/2012 12:39:16 PM(UTC)
washer will not drain before the spin cycle (Washer Repair)
by tondot 11/11/2012 5:32:56 PM(UTC)
