AppliancePartsPros.com
Appliance Repair Help
Washer Repair
What seals do I need when replacing outer tub bearings?
Hello,
I have a 7 yr old Neptune FAV6800AWW and it sounds like a jet taking off during the spin cycle and after reading some posts in this forum, it apparently needs the outer tub bearings replaced. The question I have is along with the two bearings I need (6207-2RS Bearing 35x72x17 Sealed), will this seal kit work (Seal KIT Washers for Maytag Kenmore Whirlpool 12002022) or do I not need all these extra parts and just need to order the tub seal and o ring?
Thanks, Dino
I think you need all of those, but if you want to use this site to order parts from call in your order and discuss it with them.
Washer Repair
