washer will not stop filling up floods house it will drian water out what part do i need
If it will not stop filling even when it is turned off, the water valve assembly is the problem.
If it stops when the machine is turned off, open it up and clean out the tube going from the water level switch to the tub. If that doesn't fix things, the water level switch itself is the likely culprit.
