Groups ready for retrieval: Registered
When washer is filling, the hot water will not shut off and washer overflows. When I turn off the hot water at the faucet valve and then turn it back on the water has stopped coming into the washer and washer works correctly until it fills in the rinse cycle and then I have to turn off hot water again. I think it is the water inlet valve on the washer because it only seems to be sticking on the hot water side. The only other thing that it could be is the water level pressure switch, but I think if it was that then both the hot and cold would still be running. I think I need to peplace the water inlet valve???
Thanks Keith
Your problem IS the inlet valve, Replace it and you will be all set!!!!:)
