Discuss
GE Front Load Washer won't tumble/spin
 in
Washer Repair
Originally Posted by yiming Hi Guys, How do you enter test/service mode? I tried press Signal-Delay-Signal-Delay per service instruction but
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE Front Load Washer won't tumble/spin
  #11 (permalink)
Old 01-27-2010, 02:11 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by yiming View Post
Hi Guys,
How do you enter test/service mode? I tried press Signal-Delay-Signal-Delay per service instruction but it doesn't seem to work. All I got is the beeping sound.
Thanks,
Yiming
What is the complete model number of the washer?
What exactly is wrong?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #12 (permalink)
Old 01-27-2010, 03:49 PM
Junior Member
yiming is on a distinguished road
Default
Thanks for the quick reply, Gene. My problem is about the same as the original poster had. The washer doesn't seem to spin. I went down the route of cleaning the filter and pump as well. The model number is WHDVH626. Although I don't see it on the machine, I found this particular model is circled out in the manual.
  #13 (permalink)
Old 01-27-2010, 08:12 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
In order to enter the test/service mode you have to press the power button to clear any current cycles first, then unplug the washer for at least 30 seconds. Reconnect power and within 30 seconds of reconnecting power press signal, delay start, signal and delay start buttons. The door will lock, then will display "t01".
__________________
  #14 (permalink)
Old 01-28-2010, 09:19 AM
Junior Member
Default
Quote:
Thanks. I was able to enter the test mode and went through different tests. Here are the results,
t02: initially returned error codes 31, 70 and maybe others I don't recall since I've reset them. Now, "t02" doesn't show any error (E00) any more.
t04: normal
t05: normal
t10: does not tumble
t11: does not spin, display "0"
t12: normal
t14: does not spin
I also tried to reprogram to different model ids (1-3) in "t01" with no success.
Any ideas from here.
Thanks, Yiming
  #15 (permalink)
Old 01-28-2010, 02:21 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The next step is to check the inverter and the motor. The instructions are attached to the reply.
Here are the breakdown diagrams and Replacement parts for General Electric WHDVH626F0GG Washer | AppliancePartsPros.com
File Type: doc How to test and replace the inverter.doc (220.0 KB, 207 views)
File Type: doc How to test and replace the motor assembly.doc (474.0 KB, 144 views)
__________________
  #16 (permalink)
Old 01-28-2010, 02:24 PM
Junior Member
Default
Thanks Gene. I was also wondering how to check the motor manually. I really appreciate your help.
  #17 (permalink)
Old 01-28-2010, 02:30 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
__________________
  #18 (permalink)
Old 01-28-2010, 06:14 PM
Junior Member
Default
Hi Gene,
I was trying to test the inverter with your instructions. But I couldn't figure out where the "AC input harness" is. It's not one of the connectors in the junction box with blue and red wires, right? Is it one on the motor from behind the inverter? I need to disconnect the connector to test the voltage right?
I guess if you can expand the instructions a bit I might be able to follow them.
Thanks,
Yiming
  #19 (permalink)
Old 01-28-2010, 08:28 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
There are plugs coming into the inverter from the control board. This is the inverter input harness. Disconnect the plug with the blue and red wires and measure the voltage between them. You can see them on the inverter picture.
__________________
  #20 (permalink)
Old 01-29-2010, 07:42 AM
Junior Member
weedy is on a distinguished road
Default
Hi Gene
I am having the same issue as the other 2 people. After I enter the service mode by unplugging hand pressing delay signal and I have the t01 displayed, what do i do next? My model # is WBVH6240. Thank you!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE front load will not spin or tumble pauldunn Washer Repair 4 05-25-2010 05:35 PM
front load washer wont tumble appliancerepair09 Washer Repair 1 09-25-2009 04:58 PM
Frigidare front load washer will not spin durning final spin cyle binky8992 Washer Repair 2 08-19-2009 06:29 PM
Frigidaire front load washer won't spin jociadam Washer Repair 1 07-03-2008 06:52 AM
Frigidaire Front Load Washer Won't Spin bbemis Washer Repair 2 11-28-2007 07:46 AM
