| » Washer Starts Then Stops |
Model Number: GLTF2940FSI Brand: Frigidaire Age: 1 - 5 years
Washer Starts /fills With Water; However, Same Shuts Off After Approximately 2 Min. And Displays Err Pause. There Is No Numeric Error Code, Just Err. It Will Drain And Spin Sometimes. If I Play With The Door/and Unplug The Machine I Can Get It To Work For A Few Minutes
Inside the lower service panel are some tech notes that will show you how to put it into a diagnostic mode and generate error codes. On your model these will be generated as flashing lights.
It sounds like the door lock assembly is bad, that is where I would concentrate. It can also be the wiring between the door lock assembly and the control unit, and if all that checks out the control unit is suspect.
__________________
| Display Modes | |
| Whirlpool Washer Starts Stops And Hums | beverlyjean | Washer Repair | 1 | 06-02-2009 02:35 PM |
| Washer starts and stops during wash cycle | ballardg | Washer Repair | 1 | 02-27-2009 04:28 PM |
| washer stops and hums, after cooldown starts again | gmboetr | Washer Repair | 1 | 05-15-2008 06:42 PM |
| washer starts to spin, then stops. won't drain | abordokas | Washer Repair | 1 | 01-24-2008 06:02 PM |
| Starts to pump during wash then shuts down, starts, stops real quidk | sirgalagit | Dishwasher Repair | 1 | 10-03-2007 08:23 PM |
