Discuss
help
 in
Washer Repair
replaced the door lock control.... still turning on & off and never getting any where. no error code because it
Appliance Repair Forum > Appliance Repair Help > Washer Repair » help
  #1 (permalink)
Old 07-18-2011, 10:38 AM
Junior Member
bonniebluegirl is on a distinguished road
Question help
Model Number: cfw5000fw0   Brand: Crosley   Age: 1 - 5 years
replaced the door lock control.... still turning on & off and never getting any where. no error code because it wont stay on long enough to see. w/ door open or closed it will turn on for 3 secs then off for 2 then on for1/2sec off on off on etc
Ads By Google
Related Models
 CFW5000FW0 CROSLEY/WASHER
Frigidaire CG05AD Frg(v1) / Chest Freezer
Frigidaire CG05AD0 Frg(v1) / Chest Freezer
Frigidaire CG05AW0 Frg(v2) / Chest Freezer
Frigidaire CG08AD Frg(v2) / Chest Freezer
Frigidaire CG08AD0 Frg(v3) / Chest Freezer
Frigidaire CG08AW0 Frg(v4) / Chest Freezer
Jenn-Air CG100 Surface Unit - Ddraft Gas
Jenn-Air CG100B Surface Unit - Ddraft Gas
Jenn-Air CG100L Surface Unit - Ddraft Gas
Jenn-Air CG100S Surface Unit - Ddraft Gas
Jenn-Air CG106B Surface Unit - Ddraft Gas
Jenn-Air CG106L Surface Unit - Ddraft Gas
Jenn-Air CG106S Surface Unit - Ddraft Gas
Frigidaire CG10AD Frg(v3) / Chest Freezer
Frigidaire CG10AD0 Frg(v5) / Chest Freezer
Frigidaire CG10AW0 Frg(v6) / Chest Freezer
Crosley CG11000ADV Range - F/s Std Gas
Crosley CG1100PAW Range - F/s Std Gas
Crosley CG1100PRA Range - F/s Std Gas
Crosley CG1100PRA-K Range - F/s Std Gas
Crosley CG1100PRW Range - F/s Std Gas
Crosley CG1100PRW-K Range - F/s Std Gas
Frigidaire CG15A Frg(v1) / Chest Freezer
Frigidaire CG15B Frg(v2) / Chest Freezer
Frigidaire CG15C Frg(v3) / Chest Freezer
Frigidaire CG15D Frg(v4) / Chest Freezer
Hardwick CG1616A49R Range - F/s Std Gas
Hardwick CG1616W49R Range - F/s Std Gas
Hardwick CG1616Y49R Range - F/s Std Gas
Hardwick CG1618A49RCB Range - F/s Std Gas
Hardwick CG1618W49RCB Range - F/s Std Gas
Hardwick CG1618Y49RCB Range - F/s Std Gas
Whirlpool CG1751XWN0
Whirlpool CG1751XWN1
Whirlpool CG1751XWW0
Whirlpool CG1751XWW1
Whirlpool CG1751XYN0
Whirlpool CG1751XYW0
Thermador CG19E
Thermador CG19F
Jenn-Air CG200 Surface Unit - Ddraft Gas
Jenn-Air CG200B Surface Unit - Ddraft Gas
Jenn-Air CG200L Surface Unit - Ddraft Gas
Frigidaire CG200SP2D1 Kel(v10) / Gas Range
Frigidaire CG200SP2D2 Frg(v2) / Gas Range
Frigidaire CG200SP2W1 Tap(v4) / Gas Range
Frigidaire CG200SP2W2 Frg(v1) / Gas Range
Jenn-Air CG205 Surface Unit - Ddraft Gas
Jenn-Air CG205W Surface Unit - Ddraft Gas
Jenn-Air CG206 Surface Unit - Ddraft Gas
Jenn-Air CG206-C Surface Unit - Ddraft Gas
Jenn-Air CG206B Surface Unit - Ddraft Gas
Jenn-Air CG206B-C Surface Unit - Ddraft Gas
Jenn-Air CG206B-E Surface Unit - Ddraft Gas
Jenn-Air CG206L Surface Unit - Ddraft Gas
Jenn-Air CG206L-C Surface Unit - Ddraft Gas
Jenn-Air CG206S Surface Unit - Ddraft Gas
Jenn-Air CG206S-C Surface Unit - Ddraft Gas
Jenn-Air CG206W Surface Unit - Ddraft Gas
Frigidaire CG20A Frg(v1) / Chest Freezer
Frigidaire CG20B Frg(v2) / Chest Freezer
Whirlpool CG2101XMW0
Whirlpool CG2101XMW1
Frigidaire CG23A Frg(v1) / Chest Freezer
Frigidaire CG23B Frg(v2) / Chest Freezer
Frigidaire CG240SP2D1 Kel(v8) / Gas Range
Frigidaire CG240SP2D2 Frg(v2) / Gas Range
Frigidaire CG240SP2D3 Frg(v2) / Gas Range
Frigidaire CG240SP2L02 Frg(v2) / Gas Range
Frigidaire CG240SP2W1 Tap(v4) / Gas Range
Frigidaire CG240SP2W2 Frg(v1) / Gas Range
Frigidaire CG240SP2W3 Frg(v1) / Gas Range
Amana CG2412 Dryer - Gas
Whirlpool CG2501XMW0
Whirlpool CG2501XMW1
Whirlpool CG2951XSW0
Whirlpool CG2951XSW1
Whirlpool CG2951XSW2
Whirlpool CG2951XSW3
Whirlpool CG2951XYG0
Whirlpool CG2951XYG1
Whirlpool CG2951XYG2
Whirlpool CG2951XYG3
Whirlpool CG2951XYN0
Whirlpool CG2951XYN1
Whirlpool CG2951XYN2
Whirlpool CG2951XYN3
Whirlpool CG2951XYW0
Whirlpool CG2951XYW1
Whirlpool CG2951XYW2
Whirlpool CG2951XYW3
Whirlpool CG2951XYW4
Thermador CG29E
Thermador CG29F
Thermador CG29FLP
Frigidaire CG300SP2D1 Frg(v2) / Gas Range
Frigidaire CG300SP2D2 Frg(v2) / Gas Range
Frigidaire CG300SP2D3 Frg(v2) / Gas Range
Frigidaire CG300SP2D5 Frg(v4) / Gas Range
Frigidaire CG300SP2W1 Tap(v4) / Gas Range
Frigidaire CG300SP2W2 Frg(v1) / Gas Range
Frigidaire CG300SP2W3 Frg(v1) / Gas Range
Frigidaire CG300SP2W5 Frg(v3) / Gas Range
Frigidaire CG300SP2WD01 Kel(v14) / Gas Range
Frigidaire CG300SP2WH01 Frg(v3) / Gas Range
Frigidaire CG300SP2WJ01 Kel(v15) / Gas Range
Frigidaire CG300SP2WL01 Frg(v2) / Gas Range
Frigidaire CG300SP2WW01 Frg(v1) / Gas Range
Frigidaire CG300SP2WY01 Gib(v9) / Gas Range
Frigidaire CG300SP2Y1 Frg(v3) / Gas Range
Frigidaire CG301SP2D03 Frg(v4) / Gas Range
Frigidaire CG301SP2D1 Frg(v2) / Gas Range
Frigidaire CG301SP2D2 Frg(v2) / Gas Range
Frigidaire CG301SP2D4 Frg(v2) / Gas Range
Frigidaire CG301SP2W1 Tap(v4) / Gas Range
Frigidaire CG301SP2W2 Frg(v1) / Gas Range
Frigidaire CG301SP2W3 Frg(v3) / Gas Range
Frigidaire CG301SP2W4 Frg(v1) / Gas Range
Frigidaire CG301SP2WD01 Kel(v14) / Gas Range
  #2 (permalink)
Old 07-19-2011, 06:58 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Inside the lower service panel there should have been some tech notes that would tell you how to troubleshoot it, but sounds like that cannot be done, so changing out the main control is your likely solution.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
