mcifonman
#1 Posted : Monday, July 18, 2011 6:31:29 AM(UTC)
mcifonman
This washer will fill, agitate, drain and fill to rinse then stops. I have replaced the timer. If you turn it off and wait, after several minutes and at times hours, when it is turned back on it will complete the cycle. It has been getting progressively worse with time. It does not matter which cycle or setting it does the same. Any help would be appreciated.
#2 Posted : Monday, July 18, 2011 2:24:09 PM(UTC)
Check the plastic hose to the water level switch, might be clogged with soap residue.
