I keep getting the F1 code when I start my machine. If i press the pause/cancel button and hit start it does it again. I do this about 2 - 3 times and then it starts. Also does the same thing when it get sto the rinse cycle.
F! is the error code for a failure of the control board. Check the wiring harness and clean the contacts and reseat them but if that does not help you are probably looking at replacing the main control unit.
