Replaced the lid switch assembly. Washer filled but wil not start agitating. Need help to narrow down the problem and a wiring shematic for the washer.
Your model number is not correct, so I can only give you the generic answer which is to trace the current through the lid switch assembly and make sure you have continuity when the switch is closed.
