Discuss
Washer spinning indefinitely. Replaced belt, timer and lubed motor slides.
 in
Washer Repair
In the past I had noticed some black rubber bits accumulating below this washer but it had been operating normally.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer spinning indefinitely. Replaced belt, timer and lubed motor slides.
  #1 (permalink)
Old 07-16-2011, 10:16 AM
Junior Member
juandiablo is on a distinguished road
Default Washer spinning indefinitely. Replaced belt, timer and lubed motor slides.
Model Number: MAVT634AWW   Brand: Maytag   Age: 5 - 10 years
In the past I had noticed some black rubber bits accumulating below this washer but it had been operating normally. Recently, it started spinning indefinitely and the timer wouldn't advance to complete the cycle.
Wash cycle worked fine and water would drain during the spin cycle but the knob wouldn't advance to stop spinning. If the timer knob was pushed in it would stop spinning, but when the knob was pulled back out the motor would only hum.
The motor slides were gummed up with debris from the old belt so while replacing the belt I thoroughly cleaned the motor plate and lubed it with silicon spray. At the same time I replaced the timer thinking it wasn't advancing because something had broken internally. Unfortunately, that didn't help and the problem still persists.
Also, when lubing the motor slides I noticed some fine white shavings inside the base of the washer but couldn't identify any source for them.
Any ideas?
Ads By Google
Related Models
Maytag MAVT634AWW Washer, Atlantis
Maytag MAVT734EWW Washer, Atlantis
Maytag MAVT754EWW Washer, Atlantis
Maytag MAVT834AWQ Washer, Atlantis
Maytag MAVT834AWW Washer, Atlantis
Whirlpool MB1110SLQ Microwave Oven 1.1 Cubic Foot
International MB1927PEHB  Ref - Maytag Int'l Bot Mount
International MB1927PEHW  Ref - Maytag Int'l Bot Mount
International MB2216PUAW Ref - Bottom Mounts
International MB2227PEHB  Ref - Maytag Int'l Bot Mount
International MB2227PEHW  Ref - Maytag Int'l Bot Mount
Thermador MB245
General Electric MB536BB1 Electric range
Whirlpool MB7120XYB0
Whirlpool MB7120XYB1
General Electric MB757WB1 Electric range
Maytag MBB1952GRQ  Ref - Bottom Mounts
Maytag MBB1952GRW  Ref - Bottom Mounts
Maytag MBB1952HEB Ref - Bottom Mounts
Maytag MBB1952HEQ Ref - Bottom Mounts
Maytag MBB1952HEW Ref - Bottom Mounts
Maytag MBB1954GEB  Ref - Bottom Mounts
Maytag MBB1954GEQ  Ref - Bottom Mounts
Maytag MBB1954GES  Ref - Bottom Mounts
Maytag MBB1954GEW  Ref - Bottom Mounts
Maytag MBB1954HEW Ref - Bottom Mounts
Maytag MBB1956GEB  Ref - Bottom Mounts
Maytag MBB1956GEQ  Ref - Bottom Mounts
Maytag MBB1956GES  Ref - Bottom Mounts
Maytag MBB1956GEW  Refrigerator
Maytag MBB1956HEB Ref - Bottom Mounts
Maytag MBB1956HEQ Ref - Bottom Mounts
Maytag MBB1956HES Ref - Bottom Mounts
Maytag MBB1956HEW Ref - Bottom Mounts
Maytag MBB2254GEB  Ref - Bottom Mounts
Maytag MBB2254GEQ  Ref - Bottom Mounts
Maytag MBB2254GES  Ref - Bottom Mounts
Maytag MBB2254GEW  Ref - Bottom Mounts
Maytag MBB2256GEB  Ref - Bottom Mounts
Maytag MBB2256GEQ  Ref - Bottom Mounts
Maytag MBB2256GES  Ref - Bottom Mounts
Maytag MBB2256GEW  Ref - Bottom Mounts
Maytag MBF1956HEB Ref - Bottom Mounts
Maytag MBF1956HEQ Ref - Bottom Mounts
Maytag MBF1956HES Ref - Bottom Mounts
Maytag MBF1956HEW Ref - Bottom Mounts
Maytag MBF1956KEB Ref - Bottom Mounts
Maytag MBF1956KEQ Ref - Bottom Mounts
Maytag MBF1956KEW Ref - Bottom Mounts
Maytag MBF2254HEB Ref - Bottom Mounts
Maytag MBF2254HEB14 Refrigerator
Maytag MBF2254HEQ Ref - Bottom Mounts
Maytag MBF2254HEQ14 Refrigerator
Maytag MBF2254HES White Westinghouse/refrigerator
Maytag MBF2254HEW Ref - Bottom Mounts
Maytag MBF2254HEW14 Refrigerator
Maytag MBF2255KEB Ref - Bottom Mounts
Maytag MBF2255KEB11 Refrigerator
Maytag MBF2255KEQ Ref - Bottom Mounts
Maytag MBF2255KEQ11 Refrigerator
Maytag MBF2255KEW Ref - Bottom Mounts
Maytag MBF2255KEW11 Refrigerator
Maytag MBF2256HEB Ref - Bottom Mounts
Maytag MBF2256HEQ Ref - Bottom Mounts
Maytag MBF2256HES Ref - Bottom Mounts
Maytag MBF2256HEW Ref - Bottom Mounts
Maytag MBF2256KEB Ref - Bottom Mounts
Maytag MBF2256KEB11 Refrigerator
Maytag MBF2256KEQ Ref - Bottom Mounts
Maytag MBF2256KEQ11 Refrigerator
Maytag MBF2256KEW Ref - Bottom Mounts
Maytag MBF2256KEW11 Refrigerator
Maytag MBF2258HEB Ref - Bottom Mounts
Maytag MBF2258HEQ Ref - Bottom Mounts
Maytag MBF2258HES Ref - Bottom Mounts
Maytag MBF2258HEW Ref - Bottom Mounts
Maytag MBF2262HEB Ref - Bottom Mounts
Maytag MBF2262HEB13 Refrigerator
Maytag MBF2262HEQ Ref - Bottom Mounts
Maytag MBF2262HEW Ref - Bottom Mounts
Maytag MBF2262HEW13 Refrigerator
Maytag MBF2556HEB Ref - Bottom Mounts
Maytag MBF2556HEQ Ref - Bottom Mounts
Maytag MBF2556HES Ref - Bottom Mounts
Maytag MBF2556HEW Ref - Bottom Mounts
Maytag MBF2556HSW Ref - Bottom Mounts
Maytag MBF2556KEB Ref - Bottom Mounts
Maytag MBF2556KEQ Ref - Bottom Mounts
Maytag MBF2556KEW Ref - Bottom Mounts
Maytag MBF2558HEB Ref - Bottom Mounts
Maytag MBF2558HEQ Ref - Bottom Mounts
Maytag MBF2558HES Ref - Bottom Mounts
Maytag MBF2558HEW Ref - Bottom Mounts
Maytag MBF2562HEB Ref - Bottom Mounts
Maytag MBF2562HEQ Ref - Bottom Mounts
Maytag MBF2562HEW Ref - Bottom Mounts
Maytag MBL1952KES Ref - Bottom Mounts
Maytag MBL1956HES Ref - Bottom Mounts
Maytag MBL1956KES Ref - Bottom Mounts
Maytag MBL2255KES Ref - Bottom Mounts
Maytag MBL2255KES12 Refrigerator
Maytag MBL2256KES Ref - Bottom Mounts
Maytag MBL2256KES12 Refrigerator
Maytag MBL2262HES Ref - Bottom Mounts
Maytag MBL2262KES Ref - Bottom Mounts
Maytag MBL2262KES12 Refrigerator
Maytag MBL2556KES Ref - Bottom Mounts
Maytag MBL2562HES Ref - Bottom Mounts
Maytag MBL2562KES 5 Qt. Stand Mixer
Maytag MBQ30 Gas Grill - B/i Stainless St
Maytag MBQ42 Gas Grill - B/i Stainless St
International MBR1415AGS Range - F/s Std Ele
International MBR1415AGW Range - F/s Std Ele
Maytag MBR1952KES Ref - Bottom Mounts
Maytag MBR1956HES Ref - Bottom Mounts
Maytag MBR1956KES Ref - Bottom Mounts
Maytag MBR1980AAB Small Appliances
Maytag MBR1980AAG Small Appliances
Maytag MBR2255KES Ref - Bottom Mounts
Maytag MBR2255KES12 Refrigerator
  #2 (permalink)
Old 07-17-2011, 05:20 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
The spinning problem can probably be fixed with a new thrust bearing, this kit here
Part number: AP4009132
but the white shavings are from the snubber.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Belt Spinning on Motor Wheel, no Tub Movement seanavent Dryer Repair 1 01-29-2011 06:57 PM
washer stop spinning found broken belt underneath machine Gouri Ramnarace Washer Repair 1 08-13-2010 08:00 AM
I replaced belt now washer overflows mieve Washer Repair 1 11-19-2009 04:33 AM
Atlantis Maytag Washer -not spinning replaced thrust bearing kit nmarie@cox.net Washer Repair 3 10-23-2008 11:33 AM
