i bought a used timer i installed it and the clock motor was dead so i took the motor off the old timer and installed it and it works all but last part of wash it hangs up .. i was wondering if the timer motor has to be tymed with the timer for it to work rite .. i sure thank u for any info u can supply thanks
In general the answer is no, the timer motor is not calibrated to the timer.
