The two small plastic pins that holds the r[FONT=Calibri","sans-serif] eceptacle [/FONT] steadh that the door latch clamp fits into broke off. It has always been difficult to get the machine to start so guess repeatedly slamming the door resulted in these small, can 2-3mm pins breaking. I have ordered the correct part but it will come in over the weekend and would like to have it repaired asap. Can anyone advise the easiest way to get to this part and replace it? I have attached the sketch of the maching and given the part number.Thanks in advance
If you review the posts and responses on this Forum you will see that there are not many Bosch posts, and even fewer responses. We are just not experienced with the brand, so I can only suggest you try to find a forum that is more suited to Bosch products.
Good luck, sorry not to be able to help more.
