| » Washing machine won't spin or agitate |
Model Number: GVW9959KT1 Brand: Whirlpool Age: 5 - 10 years
Machine fills with water but won't agitate, spin or then drain. Screen code indicates overloaded, but does the same thing even when empty. Advice?
Whirlpool Calypso Ads By Google Related Models |
Replacement parts for WHIRLPOOL GVW9959KT1 | AppliancePartsPros.com Here is the tech sheet https://www.servicematters.com/docs/...%208530143.pdf And here is a service manual https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf Hopefully the above info will help. I could not find an overloaded error code!!!
__________________
The code was Ld, which I thought was overload, but it is "long drain." I did the spin and drain test per the instructions and it did nothing but make a humming noise (like it does anytime I turn it on now.) It does have water in it.
Of course I can't do the "drain and recirculation test" so is there any way to know if it's the pump, the pump motor or the wiring harness? Thanks, Bill |
| Display Modes | |
| GE Washing Machine: NO agitate or spin | tkeane | Washer Repair | 10 | 04-15-2013 03:59 AM |
| washing machine does not agitate or spin | mikail | Washer Repair | 2 | 07-01-2009 11:52 AM |
| washing machine does not agitate or spin | mikail | Washer Repair | 1 | 06-30-2009 03:42 PM |
| ge washing machine will not spin or agitate | m-fuson | Washer Repair | 13 | 03-09-2009 03:03 PM |
| washing machine wont agitate, spin, or drain. | rathresidence | Washer Repair | 1 | 05-01-2008 03:32 PM |
