my washer was working fine then i put a load in to soak and now it will not drain or spin. When i try to turn it on to the wash it just makes a ticking sound. I checked the outlet-ok, i checked the button on the lid-ok, what do i lok for next?
Try checking the lid switch by either by passing it or checking it with a multi meter. It sounds like your problem.
