When the unit is turned on it says A problem has been detected with this unit. How do I find out what is wrong with the unit? Last time this happened A technition came out pushed some buttons
Hello #1 Puppy. Based on the information you provided, that is a fault code for a bad pressure switch or pressure hose. Make sure there are not any breaks or cuts in the pressure hose and it has not come off. If it is good, you may have a bad pressure switch. To clear the code, you will need to put the machine in service mode. To do this, from the home screen, you will press the help pad. Then press MY CYCLES and BACK pads simultaneously for three seconds. The control panel will display any recorded errors. If errors have been recorded, use the error chart in troubleshooting section for proper diagnostic procedures. Make a note of the listed errors. Then press EXIT, the screen will prompt you to unplug the washer before servicing. By pressing EXIT, the machine clears the error messages stored and activates the setup mode program. When all errors have been corrected, plug the machine back up and let it run the set up program. When completed, you should see on the screen, "Your washer is now ready for your use. Please read your user's manual prior to operation." Press ok to return the washer to normal operation. Hope this helps. Part number: AP3206676
