Discuss
washer won't spin - trying to figure out if it is door switch or timer unit
 in
Washer Repair
I have a GE Profile Washer Model WPXH214AOWW. It is a front loading washer. I was using it the other
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer won't spin - trying to figure out if it is door switch or timer unit
  #1 (permalink)
Old 03-15-2009, 11:26 PM
Junior Member
thejipster is on a distinguished road
Default washer won't spin - trying to figure out if it is door switch or timer unit
Model Number: WPXH214AOWW   Brand: GE   Age: 5 - 10 years
I was using it the other day and half way through the wash cycle, it just stopped in the middle of the wash cycle (agitation cycle).
When I manually put it to the spin cycle, the drain pump engaged and empties the water. Turning it back to the normal wash cycle, the water fills the tub.
I looked at the technician repair sheet and followed through some diagnostics.
It asked me to check the voltage on the speed control harness pin 5 and 6 to see if it registers 120V, and if it doesn't, then check the connection on the timer unit or the door lock mechanism.
I checked the voltage on pin 5 and 6 of the speed control unit and it shows 0 volts. Now, the question is how can I determine which part may be broken -- the timer unit or the door lock mechanism, causing the voltage to read 0 instead of 120v.
It is unclear to me if the speed control harness won't produce 120V on pin 5 and 6 because of a faulty timer unit or door lock mechanism. It seems to me that the timer unit relies on power produced by the speed control. Since I am new to this, I don't know exactly how to read the schematic.
The locking mechanism does lock the door when it is in the wash cycle and the door lock light does light up.
thanks
- J
Ads By Google
Related Models
General Electric WPXH214F0CC Washer
General Electric WPXH214F0WW Washer
General Electric WPXH214F1CC Washer
General Electric WPXH214F1WW Washer
General Electric WPXQ3090T2AA Washer
General Electric WPXQ3090T2WW Washer
General Electric WPXQ3090T5AA Washer
General Electric WPXQ3090T5WW Washer
General Electric WPXQ3090T6AA Washer
General Electric WPXQ3090T6WW Washer
General Electric WPXQ3090T8AA Washer
General Electric WPXQ3090T8WW Washer
General Electric WPXQ3090TAAA Washer
General Electric WPXQ3090TAWW Washer
General Electric WR30X0259 Electric range
General Electric WR30X0280 Refrigerator accessory
General Electric WR30X0283 Refrigerator accessory
General Electric WR30X0284 Refrigerator accessory
General Electric WR30X0289 Refrigerator accessory
General Electric WR30X0290 Refrigerator accessory
General Electric WR30X0299 Electric range
General Electric WR30X0303 Refrigerator accessory
General Electric WR30X0304 Refrigerator accessory
General Electric WR30X0305 Refrigerator accessory
General Electric WR30X0306 Refrigerator accessory
General Electric WR30X0307 Refrigerator accessory
General Electric WR30X0310 Refrigerator accessory
General Electric WR30X0316 Refrigerator accessory
General Electric WR30X0318 Refrigerator accessory
General Electric WR30X0320 Refrigerator accessory
General Electric WR30X0327 Refrigerator
General Electric WR30X0329 Refrigerator
General Electric WR30X0330 Refrigerator
General Electric WR30X209 Freezers
General Electric WR30X210 Freezers
General Electric WR30X211 Freezers
General Electric WR30X212 Freezers
General Electric WR30X213 Freezers
General Electric WR30X214 Freezers
General Electric WR30X234 Freezers
General Electric WR30X235 Freezers
General Electric WR30X236 Freezers
General Electric WR30X237 Freezers
General Electric WR30X238 Freezers
General Electric WR30X239 Freezers
General Electric WR30X241 Freezers
General Electric WR30X251 Freezers
General Electric WR30X252 Freezers
General Electric WR30X253 Freezers
General Electric WR30X254 Freezers
General Electric WR30X255 Freezers
General Electric WR30X259 Freezers
General Electric WR57X0095 Freezers
General Electric WR57X0098 Refrigerator accessory
General Electric WR57X47 Freezers
General Electric WR57X51 Freezers
General Electric WR57X60 Freezers
Hot Point WR57X64
Hot Point WR57X65
General Electric WR57X67 Freezers
General Electric WR57X69 Freezers
General Electric WR57X70 Freezers
Hot Point WR57X71
General Electric WR57X72 Freezers
General Electric WR57X74 Freezers
General Electric WR57X77 Freezers
General Electric WR57X78 Freezers
General Electric WR57X88 Freezers
General Electric WR57X90 Freezers
General Electric WR57X92 Freezers
General Electric WR57X93 Freezers
General Electric WR87X0260 Refrigerator
General Electric WR87X0261 Refrigerator
General Electric WR87X0262 Refrigerator
General Electric WR87X0263 Refrigerator
General Electric WR87X0264 Refrigerator
General Electric WR87X0265 Refrigerator
General Electric WR87X0266 Refrigerator
General Electric WR87X0267 Refrigerator
General Electric WR87X0268 Refrigerator
General Electric WR87X0269 Refrigerator
General Electric WR87X0270 Refrigerator
General Electric WR87X0271 Refrigerator
General Electric WR87X0272 Refrigerator
General Electric WR87X0273 Refrigerator
General Electric WR87X0274 Refrigerator
General Electric WR87X0275 Refrigerator
General Electric WR87X0276 Refrigerator
General Electric WR87X0277 Refrigerator
General Electric WR87X0278 Refrigerator
General Electric WR87X0279 Refrigerator
General Electric WR87X0280 Refrigerator
General Electric WR87X0290 Refrigerator
General Electric WR87X0291 Refrigerator
General Electric WR87X0293 Refrigerator
General Electric WR87X0295 Refrigerator
General Electric WR87X0298 Refrigerator
General Electric WR87X0299 Refrigerator
General Electric WR87X0300 Refrigerator
General Electric WR87X0301 Refrigerator
General Electric WR87X0303 Refrigerator
General Electric WR87X0305 Refrigerator
General Electric WR87X0308 Refrigerator
General Electric WR87X0310 Refrigerator
General Electric WR87X0311 Refrigerator
General Electric WR87X0315 Refrigerator
General Electric WR87X0318 Refrigerator
General Electric WR87X0321 Refrigerator
General Electric WR87X0325 Refrigerator
Frigidaire WRS20PRBD0 Wwh(v1) / Side By Side Refrigerator
Frigidaire WRS20PRBD1 Wwh(v1) / Refrigerator
Frigidaire WRS20PRBW0 Wwh(v2) / Side By Side Refrigerator
Frigidaire WRS20PRBW1 Wwh(v2) / Refrigerator
Frigidaire WRS20PRCD0 Wwh(v1) / Refrigerator
Frigidaire WRS20PRCD1 Wwh(v1) / Side By Side Refrigerator
Frigidaire WRS20PRCW0 Wwh(v2) / Refrigerator
Frigidaire WRS20PRCW1 Wwh(v2) / Side By Side Refrigerator
Frigidaire WRS20WRHD0 Wwh(v1) / Side By Side Refrigerator
Frigidaire WRS20WRHD1 Wwh(v1) / Refrigerator
Frigidaire WRS20WRHD2 Wwh(v1) / Side By Side Refrigerator
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Washer Stacked Unit will not spin all the way shaucan Washer Repair 3 01-07-2010 04:19 PM
Series 90 Washer Timer switch? apowers225 Washer Repair 5 09-09-2009 07:07 PM
washer door switch waxman Washer Repair 1 06-22-2009 05:09 PM
washer door switch waxman Washer Repair 0 06-21-2009 06:48 PM
Can't figure out problem with washer mr1drful Washer Repair 1 04-21-2009 09:32 AM
