| » Thin Twin washer dryer |
Sounds like the water level control is shot.
Especially if turning the unit off or unplugging it stops the water flow. This tells you that the water valves themselves are OK. The way it works is, it is a pressure switch. It has a tube that runs to the bottom of the tub. Water rises in this tube as the washer fills, this increases the air pressure in the tube. When the pressure reaches the set point a switch activates, this turns the water off and begins the agitate cycle. So the problem is 1. The level control is shot. Get a tube with the same internal diameter, attach this to the level control. Start a wash, blow into the tube, you should be able to activate the switch (turn the water off) without blowing into the tube overly hard. 2. Something is blocking the end of the tube preventing the water from entering it. Undo the tube at the level control and blow into it. 3. The tube is leaking or not sealing at the level control. Inspect it for cracks, holes etc. Cut half an inch on the end and re-seat it to the control.
__________________
thanks for that if that doesnt work then i can assume its the switch the sending tube is talking to is bad correct??
Not quite sure what you mean. The switch is part of the level control. You did not include a Model Number so I could not look for a wiring diagram.
__________________
Here is your parts breakdown
Replacement parts for WHIRLPOOL LT5000XSW2 | AppliancePartsPros.com One end is Item 10 in the Washer/dryer control section Other end is Item 11 in Tub & basket section Here is a manual which should help https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/7d322131b309497a852571ca006ce7d2/$FILE/L-56_4314124A.pdf And here is a decent wiring diagram, may not need it now but might come in handy in the future https://www.servicematters.com/docs/...%203388366.pdf
__________________
| Display Modes | |
| Whirlpool thin twin stackable washer and dryer | numisman1@yahoo.com | Dryer Repair | 2 | 12-14-2009 08:21 PM |
| leaking whirlpool thin twin washer | trevorroehl | Washer Repair | 1 | 09-06-2009 05:21 PM |
| Twin & Thin washer/dryers | Apeche | Washer Repair | 3 | 07-21-2009 06:31 PM |
| Whirlpool Thin Twin Washer Problem | mineolabauer | Dryer Repair | 1 | 12-01-2008 08:45 AM |
| Thin Twin Washer Dryer | Theadore | General Talk | 1 | 08-30-2007 01:28 PM |
