Discuss
Maytag top-load won't spin properly
 in
Washer Repair
Question regarding: Maytag LAT9593AAL Top Loading Washing Machine The washer stopped spinning, but will still pump out water. I did
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag top-load won't spin properly
  #1 (permalink)
Old 03-15-2009, 06:28 AM
BenRosey BenRosey is offline
Junior Member
BenRosey is on a distinguished road
Default Maytag top-load won't spin properly
Model Number: LAT9593AAL   Brand: Maytag   Age: More than 10 years
The washer stopped spinning, but will still pump out water. I did some investigation, but I'm not sure where the problem lies. I went to a troubleshooting website that lists multiple parts that could be bad, and I'm not sure how to isolate which it is.
I first noticed this problem when I checked my laundry and smelled a burning smell (the belt) and noticed that everything was still soaking wet, because the machine hadn't spun everything.
Switch is fine. I looked at the belts, and the transmission/agitator belt was a little old/loose. So I replaced it with another. During the process, I removed the tub to see if there was anything obviously wrong beneath (I've done this before for another project, so it was familiar and quick for me). Once I did that, I turned it on and the shaft spun easily. When I put the tub back into place (with the new belt), the tub will spin for 4-5 seconds, but then the motor kicks off and starts smoking (as if it has too much load on it). This happened repeatedly.
Also, there are no unusual sounds or loud noises when it's spinning.
I must note that the tub seems much harder than normal to spin, as if something is seized up somewhere. But it's obviously not totally locked as I can still spin it. Let me know where to start, or what might be the problem. I have the parts diagrams, just need to know what might be the cause, or how to isolate things further. I don't think it's the motor. Thank you for your help. It's somewhat old, but otherwise a nice washer that I'd hate to see go to the graveyard.
Please let me know if there are any other (inexpensive) parts that frequently go bad that I should replace as preventative maintenance during this repair.
Related Models
Maytag LAT9593AAL Washer - Top Loading
Maytag LAT9593AAW Washer - Top Loading
Maytag LAT9593ABL Washer - Top Loading
Maytag LAT9593ABW Washer - Top Loading
Maytag LAT9600AAL Washer - Top Loading
Maytag LAT9600AAW Washer - Top Loading
Maytag LAT9600ABL Washer - Top Loading
Maytag LAT9600ABW Washer - Top Loading
Maytag LAT9604AAE Washer - Top Loading
Maytag LAT9604AAL Washer - Top Loading
Maytag LAT9604AAM Washer - Top Loading
Maytag LAT9604ABE Washer - Top Loading
Maytag LAT9604ABL Washer - Top Loading
Maytag LAT9605AAE Washer - Top Loading
Maytag LAT9605AAM Washer - Top Loading
Maytag LAT9606AAE Washer - Top Loading
Maytag LAT9606AAM Washer - Top Loading
Maytag LAT9606ABE Washer - Top Loading
Maytag LAT9606ABM Washer - Top Loading
International LAT9606AGE Washer - Top Loading
International LAT9606BGE Washer - Top Loading
International LAT9606GGE Washer - Top Loading
Maytag LAT9614AAE Washer - Top Loading
Maytag LAT9614AAL Washer - Top Loading
Maytag LAT9614AAM Washer - Top Loading
Maytag LAT9615AAE Washer - Top Loading
Maytag LAT9615AAM Washer - Top Loading
Maytag LAT9616AAE Washer - Top Loading
Maytag LAT9616AAM Washer - Top Loading
Maytag LAT9634AAE Washer - Top Loading
Maytag LAT9634AAL Washer - Top Loading
Maytag LAT9634AAM Washer - Top Loading
Maytag LAT9634ABE Washer - Top Loading
Maytag LAT9635AAE Washer - Top Loading
Maytag LAT9635AAM Washer - Top Loading
Maytag LAT9700AAG Washer - Top Loading
Maytag LAT9700AAL Washer - Top Loading
Maytag LAT9700AAW Washer - Top Loading
Maytag LAT9700AAX Washer - Top Loading
Maytag LAT9700ABL Washer - Top Loading
Maytag LAT9700ABW Washer - Top Loading
Maytag LAT9700DAG Washer - Top Loading
Maytag LAT9700DAL Washer - Top Loading
Maytag LAT9700DAW Washer - Top Loading
Maytag LAT9704AAE Washer - Top Loading
Maytag LAT9704AAL Washer - Top Loading
Maytag LAT9704AAM Washer - Top Loading
Maytag LAT9704ABE Washer - Top Loading
Maytag LAT9704ABL Washer - Top Loading
Maytag LAT9704ABM Washer - Top Loading
International LAT9704AGE Washer - Top Loading
International LAT9704BGE Washer - Top Loading
Maytag LAT9704DAL Washer - Top Loading
Maytag LAT9704DAM Washer - Top Loading
International LAT9704GGE Washer - Top Loading
Maytag LAT9706AAE Washer - Top Loading
Maytag LAT9706AAM Washer - Top Loading
Maytag LAT9706AAQ Washer - Top Loading
Maytag LAT9706ABE Washer - Top Loading
Maytag LAT9714AAE Washer - Top Loading
Maytag LAT9714AAL Washer - Top Loading
Maytag LAT9714AAM Washer - Top Loading
Maytag LAT9734AAE Washer - Top Loading
Maytag LAT9734AAL Washer - Top Loading
Maytag LAT9734AAM Washer - Top Loading
Maytag LAT9734ABE Washer - Top Loading
Maytag LAT9734ABL Washer - Top Loading
Maytag LAT9757AAE Washer - Top Loading
Maytag LAT9757AAM Washer - Top Loading
Maytag LAT9766AAE Washer - Top Loading
Maytag LAT9800AAL Washer - Top Loading
Maytag LAT9800AAW Washer - Top Loading
Maytag LAT9800ABL Washer - Top Loading
Maytag LAT9800ABW Washer - Top Loading
Maytag LAT9800AGL Washer - Top Loading
Maytag LAT9800AGW Washer - Top Loading
Maytag LAT9800AGX Washer - Top Loading
Maytag LAT9804AAE Washer - Top Loading
Maytag LAT9804AAL Washer - Top Loading
Maytag LAT9804AAM Washer - Top Loading
Maytag LAT9804ABE Washer - Top Loading
Maytag LAT9806AAE Washer - Top Loading
Maytag LAT9806AAM Washer - Top Loading
Maytag LAT9806ABE Washer - Top Loading
International LAT9806AGE Washer - Top Loading
International LAT9806AKM Washer - Top Loading
International LAT9806AKQ Washer - Top Loading
International LAT9806BGE Washer - Top Loading
International LAT9806DAM Washer - Top Loading
International LAT9806DAQ Washer - Top Loading
International LAT9806GGE Washer - Top Loading
Maytag LAT9824AAE Washer - Top Loading
Maytag LAT9824AAL Washer - Top Loading
Maytag LAT9824AAM Washer - Top Loading
Maytag LAT9824ABE Washer - Top Loading
Maytag LAT9824ABL Washer - Top Loading
Maytag LAT9824ABM Washer - Top Loading
International LAT9824AGE Washer - Top Loading
International LAT9824AKM Washer - Top Loading
International LAT9824BGE Washer - Top Loading
International LAT9824DAM Washer - Top Loading
International LAT9824GGE Washer - Top Loading
Maytag LAT9900AAL Washer - Top Loading
Maytag LAT9900AAW Washer - Top Loading
Maytag LAT9900ABL Washer - Top Loading
Maytag LAT9900ABW Washer - Top Loading
Maytag LAT9904AAE Washer - Top Loading
Maytag LAT9904AAL Washer - Top Loading
Maytag LAT9904AAM Washer - Top Loading
Maytag LAT9904ABE Washer - Top Loading
Admiral LATA100AAE Washer - Top Loading
Admiral LATA100AAL Washer - Top Loading
Admiral LATA100AAM Washer - Top Loading
Admiral LATA100AAW Washer - Top Loading
Admiral LATA100AGE Washer - Top Loading
Admiral LATA100AJE Washer - Top Loading
Admiral LATA100AKE Washer - Top Loading
Admiral LATA100ARE Washer - Top Loading
Admiral LATA200AAE Washer - Top Loading
Admiral LATA200AAL Washer - Top Loading
  #2 (permalink)
Old 03-15-2009, 03:41 PM
Junior Member
Default
Update: Looks like problem had solved. I thought that it was just the belt and that when I put the outer tub top piece in place I had it down too tight to the inner tub, which caused the resistance and smoking of the motor.
I ran another cycle, agitation worked fine, but the motor smoked itself out and kicked off in spin.
Any thoughts?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Washer not agitating properly bfavinger Washer Repair 1 02-21-2009 03:00 AM
Spin Cycle not working properly gdonwallace Washer Repair 0 01-27-2009 02:24 PM
Maytag won't hold temp properly StNick55 Oven Repair (including Ranges and Cooktops) 1 12-24-2008 06:57 AM
Maytag Top load Washer died TXwannabe Washer Repair 4 08-17-2008 08:26 PM
Maytag dryer not heating up on all cycles and not properly drying clothes. radioman464 Dryer Repair 1 10-18-2007 04:48 AM
