GE model WJRE5500GOWW washer refills and starts through cycles again after final spin cycle. Must unplug to stop cycling. Any suggestions will be appreciated.
You have a built in diagnostic code generator on the inverter which is on the motor. Use this guide HydroWave GE Washer Repair Guideto see if you are getting codes, but first use it to clear the codes. That may fix things.
