Here's some information and basic instructions, that should get you up and going :
Should you have to remove the spin basket/tub to complete the repair you will need a spanner wrench.
1. Remove the front by pushing a butter knife (or anything flat, I usually use my truck keys) between the top and the front in line with the grove in the lid .
2. Remove the ¼ inch screws that hold the top on.
3. Remove the top. Note that you have to remove the lid switch if your washer has a magnetic lid switch and if it has a mechanical lid switch you must unplug it.
Agitator Removal
In this section of this GE washer disassembly guide I will walk you through the steps in disassembling the the agitator-coupling.
1. The agitator just lifts straight up and out. Note that it may be hard but if you can get your fingers under it and rock it back and forth it will slip up. Also note that if you are unable to get your fingers under it you can slip a belt under it and pull from the belt.
2. Under the agitator you should see the agitator-coupling, remove it using a 7/16 socket.
Spin Basket Removal/Tub seal Replacement
In this section of this GE washer disassembly guide I will walk you through the steps in disassembling the tub seal.
1. Follow steps in top and front removal and agitator removal.
2. Next remove the four 5/16" screws that hold the damping straps on.
3. Unhook the drain hose on the bottom of the tub.
4. Unhook the small water level tube on the left hand side.
5. Unplug the motor and remove the ground screw.
6. Lift up on the tub and unhook all four of the suspension rods.
7. Lift up on the whole unit and bring it out of the case bottom first .
8. Remove the cover off of the tub . Note be careful not to over bend the tabs or it may not snap back in place.
9. Remove the left-handed 1-11/16 hub nut. Note that the tool mentioned is a spanner wrench designed for removing this nut. Also note that you may be able to remove this nut using a wrench but typically they are too long so if you have to buy a tool to remove this nut, buy the one I describe above.
10. Lift the spin basket up and out of the tub.
11. Remove the split ring. Note this split ring will break easily, so be careful.
12. Remove the hub washer.
Note that at this point in GE washer disassembly you can replace the tub seal. Just use a screwdriver to pry the old one out. Then tap the new one in with a blunt object such as a nut driver with out a socket making sure it is seated good.
1. Follow steps in Top and front removal, agitator removal and spin basket removal.
2. Turn the tub assembly over on the floor.
3. Remove the ¾" nuts holding the transmission pulley on. Note that you have to somehow stop the pulley from turning in order to remove the nut. They make a special tool for this but I do it without the tool. Also you can hold the belt by hand.
4. Remove the four 3/8" screws that hold the transmission to the platform
5. Remove the ½ inch screws that hold the platform to the tub.
6. Lift the platform up and off of the transmission.
7. Lift the transmission up and out of the tub.
8. Using a long screwdriver knock the old tub seal out from the bottom of the tub.
Motor and clutch removal
1. Remove the front as shown in the first step in front and top removal.
2. Remove the 3/8-inch nuts under the motor.
3. Turn the transmission to allow you to lean the motor back and slide it out.
4. To remove the clutch (not on newer models) turn the motor over and remove the clip that holds the clutch on.
5. Lift the clutch up and off the motor shaft.
Good Luck,
