| » Fills and stops |
Model Number: A9200 Brand: Maytag Age: More than 10 years
The washer will fill and not advance, replaced timer motor to no avail.
To begin the cycle after filling requires a bump IE fist to the top, jolt to control panel, will start the timer motor and continue the cycle. Related Models |
The first thing I would check is the water level switch. Check for continuity between terminals 7 and 16. If it's open replace the switch.
- The part number for the water level switch AP245700 - Here are the break down diagrams for the Maytag washer Model A9200 Gene.
__________________
Professional appliance repair in Orange County, California. |
I need more specific information describing the problem with your washer.
The model number you posted is incomplete. Gene.
__________________
I'm having a similar problem with a Maytag A9200. It fills then, stops working. If I drop the lid, it kicks on. I replaced the lid switch, but that didn't work.
How can I determine which terminals are which (ie, 16 and 7)? It looks like some of the wires have the numbers on them. Are those the terminal numbers that I'm looking for? I unplugged the washer and attempted to test the continuity between 16 and 7 and it appears that its a closed connection. Is the test still valid with the washer unplugged? Is it safe to test it while its plugged in? Sorry, I'm a newbie at washer repair. Any help is appreciated! |
Sounds like the problem is with the lid switch. Which part of the lid switch did you replace?
You can find the more specific instructions in the service manual. - Here are the break down diagrams for the Maytag washer Model A9200 Happy New year! Gene.
__________________
I have a whirlpool washer, model# LA5668XSW1, that will not go into the agitate or spin cycles unless I grab the drum and either work it back and forth or try to spin the drum by hand. I can hear the motor humming as if jambed and if I do not catch it quick enough the washer kicks off. On the older washing machines they had a "wig-wag" solenoid. I do not see this on the direct drive model. Where do I go from here?
The first thing I would check is the motor wire harness and the motor plug connections.
Also check the capacitor (#34 on the controls and rear panel break down diagram). If there is nothing wrong then the motor start winding is bad and the motor has to be replaced. - The part number for the motor is AP2905451 - The part number for the capacitor is AP3866194 - Here are the break down diagrams for the Whirlpool washer Model LA5668XSW1 Good luck. Gene.
__________________
| Display Modes | |
| Washer Fills, Then Stops | yogivic54 | Washer Repair | 4 | 01-02-2010 01:03 PM |
| washer fills and stops | gabednar | Washer Repair | 1 | 09-19-2009 06:53 PM |
| washer fills then stops | julie larson | Washer Repair | 3 | 01-07-2009 03:55 AM |
| Bosch dishwasher fills, drains, fills again then stops | ricsan | Dishwasher Repair | 1 | 06-05-2008 03:40 AM |
