Discuss
Kenmore 90 Series Does Not Spin/Does Agitate
 in
Washer Repair
Kenmore 90 Series, model number 110.28922790. Over the course of 12 years, I've replaced the motor coupling and and installed
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore 90 Series Does Not Spin/Does Agitate
  #1 (permalink)
Old 07-08-2011, 01:13 PM
Junior Member
mosigma is on a distinguished road
Default Kenmore 90 Series Does Not Spin/Does Agitate
Model Number: 110.28922790   Brand: Kenmore   Age: More than 10 years
Kenmore 90 Series, model number 110.28922790. Over the course of 12 years, I've replaced the motor coupling and and installed an agitator kit because it was not agitating (two separate incidents). About 6 months ago, it stopped agitating falling a very rough spin cycle. Found the motor coupling not aligned.
Today, the machine made grinding noises during agitation. Pulled machine apart to check motor coupling. Grinding noises went away once it was put back together, but machine does not spin. Double checked my work and confirmed that agitation is great in all speeds, but tub does not spin.
I don't know what could cause the machine to agitate but not spin. Please help!
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 07-10-2011, 05:01 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Well if it is draining, then the motor is runnng during the spin time and the problems can be the clutch/brake assembly or the transmission.
__________________
  #3 (permalink)
Old 07-11-2011, 08:26 AM
Member
splumer is on a distinguished road
Default
Quote:
I also have Kenmore Series 90 that didn't spin. It was the clutch. There are three plastic pads in the clutch, and mine were all severely worn. One had even started to turn sideways. Replacing it really isn't that hard of a job. I made it a lot harder for myself, but had I known I just had to replace the clutch it wouldn't have been hard at all.
The two problems I ran into were:
1. getting the transmission back on. It just wouldn't go in far enough. I tapped the agitator rod (not sure of actual name) back into the trans a bit, just enough that the trans mounting bolts would catch, then tightened the bolts to bring the trans back up to where it needed to be.
2. The skate plate was out of place, which caused it to go out of balance at high spin speeds. I had had the washer on its front and sides in the course of the repair, which threw the plate out of place, and I didn't know how important the skate plate was. Make sure it's aligned with the triangular base when you set the washer back on its feet.
Feel free to ask more questions. I just finished doing this two days ago. Good luck!
  #4 (permalink)
Old 07-12-2011, 07:33 AM
Junior Member
Kirby Joe is on a distinguished road
Default
How does one diagnose whether it's the clutch, brake or transmission?
  #5 (permalink)
Old 07-12-2011, 09:02 AM
Member
Default
Quote:
The way I found out it was the clutch was I expected it to be the motor coupler. I started out working on it with that in mind, then I found that it was in perfect shape. I kept taking stuff off (pump, motor, transmission) and eventually found the clutch, and saw that that three pads on it were visibly worn, one so bad it was turning sideways. I read online that worn clutches are the result of frequent overloading. My kids do a lot of our laundry, so I wasn't surprised at all.
I've subsequently been told that our brakes might be bad too, but the washer seems to work fine, so I'm letting sleeping dogs lie on that one. I think if the brakes are binding, when the washer is in spin mode, it will be difficult to turn by hand (i.e., the brakes are holding it back). In mine, I could get it to spin by hand, and once I got it spinning it would go by itself. The clutch is a circular metal band with the ends held together with a spring. It resides in a shiny metal housing about the size and shape of a Petri dish. When I bought my new one, I had to get all the parts, not just the clutch itself. It came to about $70 at my local parts store, though you could probably find it cheaper online. The dude at the parts store was really helpful, too.
I Googled "kenmore washer transmission troubleshooting" and found this a site called "****************" that had some good info. For some reason I can't post the link.
It seems like a good guide for diagnosing trans problems. I think, though, if it agitates, the trans should be OK. But don't quote me on that.
  #6 (permalink)
Old 07-12-2011, 09:05 AM
Member
Default
Apparently this site REALLY doesn't like other sites. Just Google what I did, and you'll find it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kenmore 70 series washer won't agitate or spin jjd2009 Washer Repair 3 07-04-2011 07:18 PM
Kenmore 80 Series won't spin or agitate Mirage_Man Washer Repair 2 08-24-2010 09:44 AM
Kenmore 80 Series Won't Agitate Will Spin meganandkids Washer Repair 5 01-08-2010 02:32 PM
Kenmore 90 Series - NO spin, agitate, or drain americanautomobile Washer Repair 1 08-24-2009 04:54 PM
Kenmore 90 Series - NO spin, agitate, or drain americanautomobile Washer Repair 1 08-23-2009 10:00 AM
