How do I replace the belt?
What is the model number?
If this is a top load Maytag washer you maybe able to just tip the washer back and see the belts from the bottom of the washer. Roll the old one off and roll the new one on.
If this is a front load washer then you will need to remove the back of the washer to replace the belt.
