| » Front load washer fills with door open |
Model Number: GHW9150PW0 Brand: Whirlpool Age: 1 - 5 years
We have a Duet washer Model # GHW9150PW0. We returned home yesterday after 13 days to find water all over laundry room floor. Washer door had been left open as we always do. Water filled tub then on to floor. Is this normal? Any idea on what has failed? All hoses are tight and not leaking. We have done 7 loads of wash since with no problems. Insurance Co. is demanding a repair invoice to show it's been fixed. Any help would be great. Thanks
Replacement parts for WHIRLPOOL GHW9150PW0 AUTOMATIC WASHER | AppliancePartsPros.com Sounds like the inlet valve may be leaking. To confirm this unplug the unit and and see if you can her water entering the tub. If no sound leave it for a few days to see if water is filling the tub, just check it on a regular basis. If it is filling then I would replace the valve. Here is a manual which should help with the repair. Although not an exact match it should be close. L-68 Whirlpool Duet Front Loading Washers Service Manual - ApplianceDigest.com You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer. If it does not fill then my guess would be that the valve leaked just that one time or the control board went weird and turned the valve on.
__________________
| Display Modes | |
| Front Load Washer will not lock door | timm | Washer Repair | 1 | 03-03-2011 01:08 PM |
| Front load washer fills with water when off | volunteer2 | Washer Repair | 1 | 03-05-2010 03:44 PM |
| Front load washer drum won't rotate once it fills with water | christizie | Washer Repair | 2 | 03-04-2010 03:46 AM |
| Front Load Washer fills with water between loads | bobfarrel@aim.com | Washer Repair | 2 | 09-29-2009 12:03 PM |
| Front Load Washer Door Stuck | GlennaA | Washer Repair | 1 | 07-11-2008 06:52 PM |
