Fills with water
My washer fills with water when not on...What do i do?
If you have water entering the tub when not in use, then one of the fill valves (AP3128776) is not sealing and is allowing water through the valve. Sometimes the problem will fix itself after a few loads if it is just something like sand in the line causing the problem, but if it keeps doing it, then replace the valve before it gets to bad.
| All times are GMT -7. The time now is 07:53 PM. |
