So the little woman yells at me "Great the washer didn't drain".
I ran it through some of the other timer settings and yep it won't drain on it's own. I've read other post saying to bypass the lid switch and check for 120v @ the pump. Looking for other items to check while I'm into this thing.
Suggestions? Advice?
By pass the lid switch and then move the timer to the spin area on the dial. If it drains and spins, replace the lid switch.
If it will not agitate then check the coupling.
