by replacing this timmer on the machine do you think their could be anything else wrong with the washer machine. because it do wash clothes but it will not spin out the water in the machine.
Check the LID SWITCH!!!!!!!!!!!:)
could you please tell me what is a LID switch and where is it located on the machine.
thanks
AP3180933 or #11 in the diagram Its mounted under the console panel:)
i see your ap3180933, does this part work also with my model number lxr7244pqo. also we have not replaced the timmer as of yet but should we replace this switch first or do we do the timmer first since cost is a factor in this a $67.00 part compare to a $13.00 part.
thanks
I believe that the intire problem is the LID SWITCH!!! But, you must check it first!!!
