Recently replaced a torn door gasket that had caused the unit to leak into a catch tray. After putting back together and plugging it in the drain motor starts as soon as it is plugged in and will not stop. It will allow you to select a wash cycle but will not start, the whole time the drain motor is running. I have drained out the unit through the filter catch. Will not allow to go into test mode either.
Not going into test mode is a pretty strong clue that the main control unit needs to be replaced.
