| » spin and drain problem calypso |
Model Number: 110-21062000 Brand: Kelvinator Age: 5 - 10 years
I have a kenmore calypso top load washer that seems to wash ok but stops when it reaches the rinse/spin cycle. it seems to get stuck in a loop where the motor starts and stops while water seems to squirt into the drum. I have taken the control console, back and bottom panels off. checked the pump and motor both spin ok and i did not see anything in the pump itself, i have also checked the continuity of the motor that also seems ok. The intake screen filters are not clogged (at one point I had to bail 20 gallons of water out of the tube so i know that water is able to enter the washer). Everything looks ok on a visual inspection of the machine and motor control boards and all the plugs and ground connections seem solid. The washer is not displaying any error codes. I suspect that one of the 2 control boards is the problem but not sure which (my guess is the machine control). HELP!!
Ads By Google Related Models Last edited by jim806 : 06-28-2011 at 06:21 PM. Reason: incorrect brand |
| Display Modes | |
| Calypso Won't Spin or Drain | RoseFamily5 | Washer Repair | 0 | 07-29-2008 07:58 AM |
| Drain / Spin Problem | JohnB1984 | Washer Repair | 2 | 01-25-2008 04:43 PM |
| Spin/Drain Problem | ttaylor | Washer Repair | 1 | 01-18-2008 12:29 PM |
| Calypso won't drain | searay210 | Washer Repair | 1 | 01-15-2008 07:13 PM |
| drain/spin problem | lymtics | Washer Repair | 1 | 10-29-2007 03:48 PM |
