Kenmore Washing Machine Model #110-20722990:
My washing machine runs through each cycle fine - no timer issue, fills fine, agitates fine, drains fine. When it comes time to drain, the tub does not spin unless I stop the machine by pulling the dial out, let it "engage" (I say this because it makes a slight THUNK sound like something has engaged in there) and then start it again. After that, it drains and spins fine. This means that I have to be present each time I do a load of laundry. Kill me.
Help!
