| » Faulty Direct Drive Pumps? |
Model Number: LSQ9110PWO Brand: Whirlpool Age: 1 - 5 years
Help! I have a Whirlpool Washing Machine that was purchased in July of '04 and has since had 3 direct drive pumps replaced on it. Can anyone tell me why this is happening? I am almost to the point of being afraid to use the machine because when this happens, of course, water starts leaking! What am I doing wrong, or is the machine a lemon?
Related Models |
i don,t think the pump is faulty,is it possible that the washer is trying to spin when draining?If so there could be a problem with the neutril drain gear in the gearcase.. this will cause leaking water..
__________________
Are you saying that perhaps the gear is slipping after a certain period of time? A new pump has been installed once a year, basically for a machine that is only 3 years old. It does not sound like making a repair to the gear will be worth the money! Or, do you think that in another year, the pump will go out because of this neutral gear slip? (I have not noticed that the machine tries to spin while draining-repairmen keep saying that a string or dust is clogging the pump causing the bearings to fail)
what i,am saying is if the nuetril drain is bad in the transmission the washer will try to spin with water in the tub. This will cause the water to go over the tub thus signs of water on the floor,some gear cases [trans] may carries some sort of warranty.Chech your washer guide.
__________________
Water is not going over the tub--it is coming out where the direct drive pump is located at the bottom of machine. I watched the most recent repairman--he said he pulledsome type of string out of the pump/bearing case and perhaps this was the culprit. He also added that perhaps I wash too many clothes-HA! Something is causing this pump to fail--if it is the gears, should I suggest this the NEXT time the thing breaks?
| Display Modes | |
| Bosch drain pumps does not turn off? | dallymemally | Dishwasher Repair | 3 | 09-26-2009 04:47 PM |
| Whirlpool Direct Drive - reasons for drive coupling failing | FriarTuck | Washer Repair | 1 | 11-12-2007 02:34 PM |
| pumps water in and out without spinning of the drum | punjabiflute | Washer Repair | 0 | 10-30-2007 05:36 PM |
| Faulty spray arm blockage message | Dave Northrop | Dishwasher Repair | 5 | 10-02-2007 11:41 PM |
| Direct Drive Washer | JNOLES | Washer Repair | 1 | 09-19-2007 05:24 PM |
