My washing machine will only fill to the small water level,i have replaced the water level switch, it did not fix the problem
I did not get your exact model number to come up, but it appears you have a motor with a diagnostic on it. The error codes are generated by a flashing green light. See if you have an error code, but before doing anything clear the codes. Sometimes that is all you need to do. Here are instructions. HydroWave GE Washer Repair Guide
