My washer will not spin and is making a growling/grinding noise. It will not spin at all. I need to know what I can do to fix this problem.
Remove the washer cabinet and check the motor drive coupling (#13 on the diagram). You can find the instructions attached to this post. Here are the break down diagrams and the parts list for the Whirlpool washer Model LSN2000PW0Gene.
