this machine during wash and rinse cycles stops, beeps, and flashes "H" and "F" alternating. It appears that it immediatley starts to empty. In order to get a load done we have to sit with the machine and restart it every min.
THIS FORUM IS DEAD!!!!!!! |
I read all of these threads and nobody had the easy fix - take the water hoses off of the back of the washer and take out the little screen filters and wash them. If they are ruined just remove them until you can get some new ones. The inlet opening for hot and cold water is maybe 3/8" in dimeter and just a little bit of debris in the water line clogs it up. put the hoses back on and your good to go.
5 minutes, zero dollars, you owe me a drink.
Sorry hiwestman but I have to disagree.
I would not run a unit without the filter screens. A dirty screen tells you that there is crud in the water lines. If a piece of this crud makes it into the valve it can hold the valve open. This will cause a flood.
Not a biggie if you notice it right away but can cost you thousands if you do not. |
