Discuss
water runs on rinse cycle but doesn't fil up
 in
Washer Repair
My washer will start to fill up for the rinse cycle but the tub never fills. If it's not being
Appliance Repair Forum > Appliance Repair Help > Washer Repair » water runs on rinse cycle but doesn't fil up
  #1 (permalink)
Old 06-23-2011, 09:12 AM
Junior Member
schrimfer is on a distinguished road
Default water runs on rinse cycle but doesn't fil up
Model Number: mavt236aww   Brand: Maytag   Age: 1 - 5 years
My washer will start to fill up for the rinse cycle but the tub never fills. If it's not being watched it can run water for over an hour! It mainly does this when my mom or mother-in-law uses it. ??? My mother-in-law uses an enormous amount of powdered detergent as well as liquid fabric softener. Could it have clogged something? It can go 5 wash loads (or more) and never give ME a problem but then she may use it 1 or 2 times and it starts messing up.
Ads By Google
Related Models
Maytag MAVT236AWW Washer - Top Loading
Maytag MAVT346AWW Washer - Top Loading
Maytag MAVT446AWW Washer - Top Loading
Maytag MAVT546EWW Washer - Top Loading
Maytag MAVT634AWW Washer, Atlantis
Maytag MAVT734EWW Washer, Atlantis
Maytag MAVT754EWW Washer, Atlantis
Maytag MAVT834AWQ Washer, Atlantis
Maytag MAVT834AWW Washer, Atlantis
Whirlpool MB1110SLQ Microwave Oven 1.1 Cubic Foot
International MB1927PEHB  Ref - Maytag Int'l Bot Mount
International MB1927PEHW  Ref - Maytag Int'l Bot Mount
International MB2216PUAW Ref - Bottom Mounts
International MB2227PEHB  Ref - Maytag Int'l Bot Mount
International MB2227PEHW  Ref - Maytag Int'l Bot Mount
Thermador MB245
General Electric MB536BB1 Electric range
Whirlpool MB7120XYB0
Whirlpool MB7120XYB1
General Electric MB757WB1 Electric range
Maytag MBB1952GRQ  Ref - Bottom Mounts
Maytag MBB1952GRW  Ref - Bottom Mounts
Maytag MBB1952HEB Ref - Bottom Mounts
Maytag MBB1952HEQ Ref - Bottom Mounts
Maytag MBB1952HEW Ref - Bottom Mounts
Maytag MBB1954GEB  Ref - Bottom Mounts
Maytag MBB1954GEQ  Ref - Bottom Mounts
Maytag MBB1954GES  Ref - Bottom Mounts
Maytag MBB1954GEW  Ref - Bottom Mounts
Maytag MBB1954HEW Ref - Bottom Mounts
Maytag MBB1956GEB  Ref - Bottom Mounts
Maytag MBB1956GEQ  Ref - Bottom Mounts
Maytag MBB1956GES  Ref - Bottom Mounts
Maytag MBB1956GEW  Refrigerator
Maytag MBB1956HEB Ref - Bottom Mounts
Maytag MBB1956HEQ Ref - Bottom Mounts
Maytag MBB1956HES Ref - Bottom Mounts
Maytag MBB1956HEW Ref - Bottom Mounts
Maytag MBB2254GEB  Ref - Bottom Mounts
Maytag MBB2254GEQ  Ref - Bottom Mounts
Maytag MBB2254GES  Ref - Bottom Mounts
Maytag MBB2254GEW  Ref - Bottom Mounts
Maytag MBB2256GEB  Ref - Bottom Mounts
Maytag MBB2256GEQ  Ref - Bottom Mounts
Maytag MBB2256GES  Ref - Bottom Mounts
Maytag MBB2256GEW  Ref - Bottom Mounts
Maytag MBF1956HEB Ref - Bottom Mounts
Maytag MBF1956HEQ Ref - Bottom Mounts
Maytag MBF1956HES Ref - Bottom Mounts
Maytag MBF1956HEW Ref - Bottom Mounts
Maytag MBF1956KEB Ref - Bottom Mounts
Maytag MBF1956KEQ Ref - Bottom Mounts
Maytag MBF1956KEW Ref - Bottom Mounts
Maytag MBF2254HEB Ref - Bottom Mounts
Maytag MBF2254HEB14 Refrigerator
Maytag MBF2254HEQ Ref - Bottom Mounts
Maytag MBF2254HEQ14 Refrigerator
Maytag MBF2254HES White Westinghouse/refrigerator
Maytag MBF2254HEW Ref - Bottom Mounts
Maytag MBF2254HEW14 Refrigerator
Maytag MBF2255KEB Ref - Bottom Mounts
Maytag MBF2255KEB11 Refrigerator
Maytag MBF2255KEQ Ref - Bottom Mounts
Maytag MBF2255KEQ11 Refrigerator
Maytag MBF2255KEW Ref - Bottom Mounts
Maytag MBF2255KEW11 Refrigerator
Maytag MBF2256HEB Ref - Bottom Mounts
Maytag MBF2256HEQ Ref - Bottom Mounts
Maytag MBF2256HES Ref - Bottom Mounts
Maytag MBF2256HEW Ref - Bottom Mounts
Maytag MBF2256KEB Ref - Bottom Mounts
Maytag MBF2256KEB11 Refrigerator
Maytag MBF2256KEQ Ref - Bottom Mounts
Maytag MBF2256KEQ11 Refrigerator
Maytag MBF2256KEW Ref - Bottom Mounts
Maytag MBF2256KEW11 Refrigerator
Maytag MBF2258HEB Ref - Bottom Mounts
Maytag MBF2258HEQ Ref - Bottom Mounts
Maytag MBF2258HES Ref - Bottom Mounts
Maytag MBF2258HEW Ref - Bottom Mounts
Maytag MBF2262HEB Ref - Bottom Mounts
Maytag MBF2262HEB13 Refrigerator
Maytag MBF2262HEQ Ref - Bottom Mounts
Maytag MBF2262HEW Ref - Bottom Mounts
Maytag MBF2262HEW13 Refrigerator
Maytag MBF2556HEB Ref - Bottom Mounts
Maytag MBF2556HEQ Ref - Bottom Mounts
Maytag MBF2556HES Ref - Bottom Mounts
Maytag MBF2556HEW Ref - Bottom Mounts
Maytag MBF2556HSW Ref - Bottom Mounts
Maytag MBF2556KEB Ref - Bottom Mounts
Maytag MBF2556KEQ Ref - Bottom Mounts
Maytag MBF2556KEW Ref - Bottom Mounts
Maytag MBF2558HEB Ref - Bottom Mounts
Maytag MBF2558HEQ Ref - Bottom Mounts
Maytag MBF2558HES Ref - Bottom Mounts
Maytag MBF2558HEW Ref - Bottom Mounts
Maytag MBF2562HEB Ref - Bottom Mounts
Maytag MBF2562HEQ Ref - Bottom Mounts
Maytag MBF2562HEW Ref - Bottom Mounts
Maytag MBL1952KES Ref - Bottom Mounts
Maytag MBL1956HES Ref - Bottom Mounts
Maytag MBL1956KES Ref - Bottom Mounts
Maytag MBL2255KES Ref - Bottom Mounts
Maytag MBL2255KES12 Refrigerator
Maytag MBL2256KES Ref - Bottom Mounts
Maytag MBL2256KES12 Refrigerator
Maytag MBL2262HES Ref - Bottom Mounts
Maytag MBL2262KES Ref - Bottom Mounts
Maytag MBL2262KES12 Refrigerator
Maytag MBL2556KES Ref - Bottom Mounts
Maytag MBL2562HES Ref - Bottom Mounts
Maytag MBL2562KES 5 Qt. Stand Mixer
Maytag MBQ30 Gas Grill - B/i Stainless St
Maytag MBQ42 Gas Grill - B/i Stainless St
International MBR1415AGS Range - F/s Std Ele
International MBR1415AGW Range - F/s Std Ele
Maytag MBR1952KES Ref - Bottom Mounts
Maytag MBR1956HES Ref - Bottom Mounts
Maytag MBR1956KES Ref - Bottom Mounts
  #2 (permalink)
Old 06-23-2011, 09:50 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Schrimfer,
Sounds like you may have a "syphon " problem, or your moms are using a higher water level, than you.
Check and make sure to top of the drain pipe is at least 36 inches high off the floor(38 to 40 is preferred), and that it is not sealed or pushed down inside the drain pipe too far. Under these conditions the the fill water can be "sucked" out of the tub as it is filling.
Excessive suds or softner, don't usually cause the issue you're describing.
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
water overflow in rinse cycle david vogel Washer Repair 1 01-06-2011 08:21 AM
Water fill is delayed, must wait to have water in rinse cycle sewsmack Washer Repair 0 10-19-2010 02:45 PM
Runs rinse cycle all the way through the spin cycle hebirdseye Washer Repair 2 07-07-2010 10:21 PM
No rinse water on spin cycle strawberry Washer Repair 2 04-26-2009 04:42 PM
no water on rinse cycle c4cdlm Washer Repair 3 12-12-2007 03:56 PM
